glitch
Hi.
I am a new AR300M user and have discovered there appear to be two different firmwares
ar300m/v1 (.bin) and ar300m/nand/v1 (.tar)
Can someone explain the difference and which one I should be using? I’m assuming it’s to do with “Nor” and “Nand” but that means zero to me also.
Thanks,
Glitch
alzhao
2
Use the nand/v1/xxx.rar
There is two system on the router. Generally you only use the Nand system.
Only if the nand firmware cannot boot for 3 times it will boot into the Nor system.
So, please use the nand/v1/xxx.rar
glitch
3
Thanks for your sift response - I got it!
