I’vr just received my AR300M with 5G module in the post. Powering it up the first issue I had was lack of DHCP. The next issue is stability, it seems after about 10 minutes or making a few changes in the UI it stops responding, the box is still operational as I can SSH, but the web interface crashes.
I just wanted to find out if anyone has a AR300M and if they’re seeing the same issues.
yes, I had to use a static., I’m still having issues with DHCP now not working. I was configuring interfaces on the box when the web interface crashes.
Should i just use UCI from now on?
Do you have an specific page or forum post that you use as a central notification point for the development of the AR300M?
