Hi, I am evaluating the AR300M to connect a device using Ethernet port to WiFi. I’d like to receive a clarification on the following questions:
1)Does the router support a connection to an existing WiFi router in client mode?
2)In affirmative case, is NAT supported in this configuration? The target WiFi router doesn’t support ‘bridge’ mode, therefore the wired device should receive an IP address from the AR300M
Many thanks for your cooperation!
Federico
