Can you just set up custom dns in the router?
One thing to note, if your dns is not accessible without vpn, please make sure in the ovpn, IP address is used instead of domain name. Otherwise openvpn will not be able to connect.
I just want to push my local dns server (specified by ip address) so that name resolution will work for my connected vpn clients. On this device the vpn client ignores this setting pushed from the openvpn server. It works for many other openvpn clients running on windows and linux.
My work around would be to configure a hosts file on this device, and maintain it. Where on disk would be the correct location to store this file?
thanks
Simon
If you want to use the push attribute, you can read this post.
