Teews
Hi all,
I have an AR750 I am using as a travel router in hotels.
It seems as though every 5 to 30 minutes the router ‘disconnects’ the clients that are using it.
The power source is good, and the lights stay lit.
Resetting the router by unplugging and plugging it back in seems to fix the issue… Any suggestions for what might be going on here?
I have done a hard reset and also updated to the latest firmware. It happens on both 2.4 and 5g ssids.
alzhao
2
What firmware version are you using?
When it disconnects, it does not reconnect back? When this happens, can you ssh to the router and get the log using command logread
I don’t know if it helps but pls try firmware 3.211 GL.iNet download center
Teews
3
I am using 3.203, I will try to update it. Is there a way I can PM you or email the log?
Teews
4
And no, it does not reconnect automatically after dropping the clients. I need to reboot the device for my clients to reconnect.
