AR750 loosing installed packages on reboot
Hi all
I do have AR750, but I noticed after installed few packages, they are gone. I think it happenes every reboot.
Is any way to make them permanent ? Or maybe to install them on sd, which I have already installed.
Thanks.
How are you installing the packages, opkg command line or Luci (advanced UI)?
Packages will be installed on flash memory so should be permanent until you do a factory reset.
Installed from Luci.
I have had this on two different devices with OpenWrt/LEDE (different manufacturers).
Both were caused by low supply voltage so might be worth checking hereā€¦
Failing that - faulty flash memory? Although I would have thought crashing would my more likely then.
I tried 5V 2A raspberry power supply. Currently on phone charger 1A, just installed few packages, seems fine. Lets saa what will happen after reboot.
