I am using my AR750 with sierra wireless EM7511 via USB port.
I am using QMI mode. In command line uqmi -d /dev/cdc-wdm0 --get-current-setting, it could display IP address. However, OpenWRT can’t recognize my IP address and no internet access. Anyone know what to do? There is no log in system log.
In both GL.iNet Admin Panel and Openwrt panel, it will recognize it is connected. But IP address won’t show up.
The EM7511 has PCIe Interface and you used a PCIe to USB adapter, right?
As far as I know Sierra uses a different driver which is not compatible with current firmware. Your other openwrt may have compiled the driver in.
The driver could be supported and I need to ask expert to have a check. If you could send logs that could be helpful. The output of the following command:
qmi_wwan 1-1:1.8: cdc-wdm0: USB WDM device
qmi_wwan 1-1:1.8 wwan0: register 'qmi_wwan' at usb-ehci-platform-1, WWAN/QMI device, 3e:xx:xx:xx:xx:xx
qmi_wwan 1-1:1.10: cdc-wdm1: USB WDM device
qmi_wwan 1-1:1.10 wwan1: register 'qmi_wwan' at usb-ehci-platform-1, WWAN/QMI device, 3e:xx:xx:xx:xx:xx
usbcore: registered new interface driver qmi_wwan
usbcore: registered new interface driver rndis_host
usbcore: registered new interface driver sierra
usbserial: USB Serial support registered for Sierra USB modem
usbcore: registered new interface driver sierra_net
usbcore: registered new interface driver option
usbserial: USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver rt2800usb
