i try to install the plugin gl-cloud-ui with no result.
After the installation (with message all successfully installed) the plugin doesn’t appear under the application tab and if i reboot the router i’m not able to reach 192.168.8.1 (error 503 and 504)… reset needed.
need help
thank you
