I’ve been unable to find the answer for my query here and I apologise if it is here and I’ve missed it.
I have a newly purchased AR750 Slate, where I’m connecting the Wan port via pppoe and I’m connecting both Lan ports to a Vlan enabled switch providing 2 separate subnets. I’ve been trying to set each of the Lan ports on the AR750 to have a separate subnet with each providing dhcp IP addresses within that subnet. However, I’m having no luck with both ports always seeming to be on the same subnet.
Is it possible to have both lans with separate subnets serving appropriate dhcp addresses?
Thanks forgetting back and pointing me in the right direction.
I did manage it by adding another vlan - vlan3 and untagging Lan1 on it and turning off Lan1 on the existing vlan 1. Then I added an interface to the new eth0.3 which worked with a separate subnet and dhcp settings.
