I was checking also via ssh to the folders of the router if there is somewhere a .config/.ovpn to manually load mine but didn’t find something at that time.
I uploaded to etc/openvpn the .ovpn file and created also a copy as .config
then I edited the /etc/config/openvpn to match the example it had as “custom_config”
managed to load the 19.07 version and indeed the ovpn options is available there.
Also managed to load the ovpn file (sidenote the instance name does NOT have to contain any dots)
Tried to start it and now:
Sat Feb 15 15:55:26 2020 daemon.err uhttpd[1288]: sh: /etc/init.d/openvpn: not found
hehe…I have to find also the way to activate the luci back since this is a clear openwrt installation.
I am not using wireguard because I read some articles that is still in the beta phase and not fully approved yet. Yes its faster and way easier to implement but not yet fully ready apparently.
Edit:
For the issue above “sh: /etc/init.d/openvpn: not found” I needed to install openvpn-openssl
I realized that the luci I was referring to is not actually the GUI of glinet which I had before and thought that this was it.
Do we know if I can add this again on-top of the new firmware?
Because now the 192.168.8.1 url its blank.
So to give an update here:
I tried the testing version 3.101 and I had issues with the internet. The connections was unstable and was dropping multiple times. I had to relogin/auth to the wifi of the hotel more than 4 times in the time window of 30 mins. Anyway; I did go back to 3.100 to be stable.
From the original config what was missing causing the failed message was actually one line. “dev tun0”
I was able to find this when I was troubleshooting on the 19.07 openwrt version and I was seeing the error messages on the system logs.
Maybe the developers can add a debug window that shows all the error messages and not just “failed”
