Hi thanks for the suggestion, i will try that
As @alzhao stated, Extender network mode uses Layer 3 relay routing:
“LAN interface of the Wi-Fi extender device MUST be on a different subnet for relayd to work (since it is routing traffic, it expects 2 different subnets). … The LAN interface subnet will be used only as a “management” interface, as devices connecting to the Wi-Fi repeater will be on the main network’s subnet instead. You will have to set your PC with a static address in the same subnet as the LAN interface (like 192.168.2.10 for our example) to connect again to the Wi-Fi repeater’s Luci GUI or SSH.”
