I have a AS750S-EXT (Slate) V3, latest firmware 3.203, and the intent is to use it as repeater of free wifi networks.
I experienced disconnections both from the those free WLans as well as from internal 2.5 and 5 Ghz networks I used to connect my tablet, phone and notebook.
Above all it was discouraging to use the free network of the city of Passau (regrettably have I no log)
This happened regardless of whether I used the phone or notebook, the type of device is irrelevant.
As I bought this router to use with a city fee WLan in the meanwhile of a relocation, and I had the landline terminated, I expected not to combat with such a problem.
Particularly annoying, this happened regularly when I used Whatsapp, sometimes I could communicate for a minute, sometimes it was just impossible to start the communication. Texting did not involve any problems and didn’t induce disconnections.
As, on the other hand, I tried to connect directly to the city’s free WLan everything worked perfectly.
Some advice?
Thanks in advance
Carlo Maria
P.S.: By the way, below is the log made with another free network in Munich, also in this case with disconnection problems with Whatsapp.
Fri Nov 5 18:39:06 2021 daemon.notice wpa_supplicant[14598]: wlan-sta: Associated with 04:62:73:29:2a:64
Fri Nov 5 18:39:06 2021 daemon.notice wpa_supplicant[14598]: wlan-sta: CTRL-EVENT-CONNECTED - Connection to 04:62:73:29:2a:64 completed [id=0 id_str=]
Fri Nov 5 18:39:06 2021 kern.debug kernel: [14867.120082] wlan-sta: Limiting TX power to 1 dBm as advertised by 04:62:73:29:2a:64
Fri Nov 5 18:39:06 2021 daemon.notice netifd: Network device ‘wlan1’ link is up
Fri Nov 5 18:39:06 2021 kern.info kernel: [14867.226943] br-lan: port 2(wlan1) entered blocking state
Fri Nov 5 18:39:06 2021 kern.info kernel: [14867.232501] br-lan: port 2(wlan1) entered forwarding state
Fri Nov 5 18:39:06 2021 daemon.notice wpa_supplicant[14598]: wlan-sta: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Fri Nov 5 18:39:06 2021 daemon.notice netifd: wwan (14635): udhcpc: started, v1.30.1
Fri Nov 5 18:39:06 2021 daemon.notice netifd: wwan (14635): udhcpc: sending discover
Fri Nov 5 18:39:07 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf IEEE 802.11: authenticated
Fri Nov 5 18:39:07 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf IEEE 802.11: associated (aid 1)
Fri Nov 5 18:39:07 2021 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 64:27:37:b5:33:cf
Fri Nov 5 18:39:07 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf RADIUS: starting accounting session 8416A4BCC96E9637
Fri Nov 5 18:39:07 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf WPA: pairwise key handshake completed (RSN)
Fri Nov 5 18:39:08 2021 daemon.info dnsmasq-dhcp[2829]: DHCPREQUEST(br-lan) 192.168.8.243 64:27:37:b5:33:cf
Fri Nov 5 18:39:08 2021 daemon.info dnsmasq-dhcp[2829]: DHCPACK(br-lan) 192.168.8.243 64:27:37:b5:33:cf VAIO-Carlo
Fri Nov 5 18:39:09 2021 daemon.notice netifd: wwan (14635): udhcpc: sending discover
Fri Nov 5 18:39:09 2021 daemon.notice netifd: wwan (14635): udhcpc: sending select for 100.80.8.191
Fri Nov 5 18:39:09 2021 daemon.notice netifd: wwan (14635): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 18:39:09 2021 daemon.notice netifd: Interface ‘wwan’ is now up
Fri Nov 5 18:39:09 2021 daemon.info dnsmasq[2829]: reading /tmp/resolv.conf.auto
Fri Nov 5 18:39:09 2021 daemon.info dnsmasq[2829]: using local addresses only for domain test
Fri Nov 5 18:39:09 2021 daemon.info dnsmasq[2829]: using local addresses only for domain onion
Fri Nov 5 18:39:09 2021 daemon.info dnsmasq[2829]: using local addresses only for domain localhost
Fri Nov 5 18:39:09 2021 daemon.info dnsmasq[2829]: using local addresses only for domain invalid
Fri Nov 5 18:39:09 2021 daemon.info dnsmasq[2829]: using local addresses only for domain bind
Fri Nov 5 18:39:09 2021 daemon.info dnsmasq[2829]: using local addresses only for domain lan
Fri Nov 5 18:39:09 2021 daemon.info dnsmasq[2829]: using nameserver 10.175.177.132#53
Fri Nov 5 18:39:09 2021 daemon.info dnsmasq[2829]: using nameserver 10.175.179.132#53
Fri Nov 5 18:39:13 2021 user.info mwan3rtmon[2641]: Detect rtchange event.
Fri Nov 5 18:39:13 2021 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
Fri Nov 5 18:46:39 2021 daemon.notice netifd: wwan (14635): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 18:46:39 2021 daemon.notice netifd: wwan (14635): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 18:54:09 2021 daemon.notice netifd: wwan (14635): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 18:54:09 2021 daemon.notice netifd: wwan (14635): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 18:59:47 2021 daemon.info dnsmasq-dhcp[2829]: DHCPINFORM(br-lan) 192.168.8.243 64:27:37:b5:33:cf
Fri Nov 5 18:59:47 2021 daemon.info dnsmasq-dhcp[2829]: DHCPACK(br-lan) 192.168.8.243 64:27:37:b5:33:cf VAIO-Carlo
Fri Nov 5 19:01:39 2021 daemon.notice netifd: wwan (14635): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 19:01:39 2021 daemon.notice netifd: wwan (14635): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 19:03:50 2021 user.info : saved ssid ignore: @BayernWLAN 1
Fri Nov 5 19:03:50 2021 user.debug : kill mwan3 track
Fri Nov 5 19:03:50 2021 daemon.notice netifd: Interface ‘wwan’ is disabled
Fri Nov 5 19:03:50 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Fri Nov 5 19:03:51 2021 daemon.notice netifd: wwan (14635): udhcpc: received SIGTERM
Fri Nov 5 19:03:51 2021 daemon.notice netifd: Interface ‘wwan’ is now down
Fri Nov 5 19:03:51 2021 daemon.warn dnsmasq[2829]: no servers found in /tmp/resolv.conf.auto, will retry
Fri Nov 5 19:03:51 2021 daemon.notice hostapd: wlan1: interface state ENABLED->DISABLED
Fri Nov 5 19:03:51 2021 daemon.notice hostapd: wlan1: AP-STA-DISCONNECTED 64:27:37:b5:33:cf
Fri Nov 5 19:03:51 2021 daemon.notice hostapd: wlan1: AP-DISABLED
Fri Nov 5 19:03:51 2021 daemon.notice hostapd: wlan1: CTRL-EVENT-TERMINATING
Fri Nov 5 19:03:51 2021 daemon.notice hostapd: nl80211: deinit ifname=wlan1 disabled_11b_rates=0
Fri Nov 5 19:03:51 2021 kern.info kernel: [16351.587769] wlan-sta: deauthenticating from 04:62:73:29:2a:64 by local choice (Reason: 3=DEAUTH_LEAVING)
Fri Nov 5 19:03:51 2021 kern.info kernel: [16351.607754] device wlan1 left promiscuous mode
Fri Nov 5 19:03:51 2021 kern.info kernel: [16351.612441] br-lan: port 2(wlan1) entered disabled state
Fri Nov 5 19:03:51 2021 daemon.notice wpa_supplicant[14598]: wlan-sta: CTRL-EVENT-DISCONNECTED bssid=04:62:73:29:2a:64 reason=3 locally_generated=1
Fri Nov 5 19:03:51 2021 daemon.err wpa_supplicant[14598]: Failed to stop hostapd AP interfaces
Fri Nov 5 19:03:51 2021 daemon.notice wpa_supplicant[14598]: nl80211: deinit ifname=wlan-sta disabled_11b_rates=0
Fri Nov 5 19:03:51 2021 daemon.notice wpa_supplicant[14598]: wlan-sta: CTRL-EVENT-TERMINATING
Fri Nov 5 19:03:51 2021 daemon.notice netifd: Network device ‘wlan1’ link is down
Fri Nov 5 19:03:53 2021 daemon.err hostapd: Configuration file: /var/run/hostapd-phy1.conf
Fri Nov 5 19:03:54 2021 daemon.notice netifd: radio1 (16829): sh: /usr/bin/ovs-vsctl: not found
Fri Nov 5 19:03:54 2021 kern.info kernel: [16354.590761] br-lan: port 2(wlan1) entered blocking state
Fri Nov 5 19:03:54 2021 kern.info kernel: [16354.596401] br-lan: port 2(wlan1) entered disabled state
Fri Nov 5 19:03:54 2021 kern.info kernel: [16354.602188] device wlan1 entered promiscuous mode
Fri Nov 5 19:03:54 2021 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->HT_SCAN
Fri Nov 5 19:03:55 2021 daemon.notice hostapd: 20/40 MHz operation not permitted on channel pri=11 sec=7 based on overlapping BSSes
Fri Nov 5 19:03:55 2021 daemon.err hostapd: Using interface wlan1 with hwaddr 94:83:c4:0e:3c:e6 and ssid “GL-AR750S-xxx”
Fri Nov 5 19:03:55 2021 kern.info kernel: [16356.092341] br-lan: port 2(wlan1) entered blocking state
Fri Nov 5 19:03:55 2021 kern.info kernel: [16356.097883] br-lan: port 2(wlan1) entered forwarding state
Fri Nov 5 19:03:55 2021 daemon.notice hostapd: wlan1: interface state HT_SCAN->ENABLED
Fri Nov 5 19:03:55 2021 daemon.notice hostapd: wlan1: AP-ENABLED
Fri Nov 5 19:03:55 2021 daemon.notice netifd: Network device ‘wlan1’ link is up
Fri Nov 5 19:04:01 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf IEEE 802.11: authenticated
Fri Nov 5 19:04:01 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf IEEE 802.11: associated (aid 1)
Fri Nov 5 19:04:01 2021 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 64:27:37:b5:33:cf
Fri Nov 5 19:04:01 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf RADIUS: starting accounting session B393D78573BF63EA
Fri Nov 5 19:04:01 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf WPA: pairwise key handshake completed (RSN)
Fri Nov 5 19:04:02 2021 daemon.info dnsmasq-dhcp[2829]: DHCPREQUEST(br-lan) 192.168.8.243 64:27:37:b5:33:cf
Fri Nov 5 19:04:02 2021 daemon.info dnsmasq-dhcp[2829]: DHCPACK(br-lan) 192.168.8.243 64:27:37:b5:33:cf VAIO-Carlo
Fri Nov 5 19:05:49 2021 user.info : saved ssid ignore: @BayernWLAN 0
Fri Nov 5 19:05:49 2021 user.info : [ 810] gl-sdk>> bIsSaved=0, ssid=@BayernWLAN, encryption=none, bssid=04:62:73:29:2A:64, wds=0, device=radio1, identity=, channel=11
Fri Nov 5 19:05:49 2021 user.info : [ 3043] gl-wifi-core>> bIsStaEnabled=1
Fri Nov 5 19:05:50 2021 daemon.notice hostapd: wlan1: interface state ENABLED->DISABLED
Fri Nov 5 19:05:50 2021 daemon.notice hostapd: wlan1: AP-STA-DISCONNECTED 64:27:37:b5:33:cf
Fri Nov 5 19:05:50 2021 daemon.notice hostapd: wlan1: AP-DISABLED
Fri Nov 5 19:05:50 2021 daemon.notice hostapd: wlan1: CTRL-EVENT-TERMINATING
Fri Nov 5 19:05:50 2021 daemon.notice hostapd: nl80211: deinit ifname=wlan1 disabled_11b_rates=0
Fri Nov 5 19:05:50 2021 kern.info kernel: [16470.473510] device wlan1 left promiscuous mode
Fri Nov 5 19:05:50 2021 kern.info kernel: [16470.478360] br-lan: port 2(wlan1) entered disabled state
Fri Nov 5 19:05:50 2021 daemon.notice netifd: Network device ‘wlan1’ link is down
Fri Nov 5 19:05:51 2021 daemon.err hostapd: Configuration file: /var/run/hostapd-phy1.conf
Fri Nov 5 19:05:51 2021 daemon.notice netifd: radio1 (19080): sh: /usr/bin/ovs-vsctl: not found
Fri Nov 5 19:05:51 2021 kern.info kernel: [16471.683005] br-lan: port 2(wlan1) entered blocking state
Fri Nov 5 19:05:51 2021 kern.info kernel: [16471.688549] br-lan: port 2(wlan1) entered disabled state
Fri Nov 5 19:05:51 2021 kern.info kernel: [16471.694378] device wlan1 entered promiscuous mode
Fri Nov 5 19:05:51 2021 daemon.err hostapd: Using interface wlan1 with hwaddr 94:83:c4:0e:3c:e6 and xxxGL-AR750S-xxx"
Fri Nov 5 19:05:51 2021 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->ENABLED
Fri Nov 5 19:05:51 2021 daemon.notice hostapd: wlan1: AP-ENABLED
Fri Nov 5 19:05:51 2021 daemon.notice hostapd: handle_probe_req: send failed
Fri Nov 5 19:05:51 2021 daemon.notice wpa_supplicant[19252]: Successfully initialized wpa_supplicant
Fri Nov 5 19:05:51 2021 daemon.notice netifd: Interface ‘wwan’ is enabled
Fri Nov 5 19:05:52 2021 daemon.notice hostapd: handle_probe_req: send failed
Fri Nov 5 19:05:52 2021 daemon.notice wpa_supplicant[19253]: wlan-sta: SME: Trying to authenticate with 04:62:73:29:2a:64 (SSID=‘@BayernWLAN ’ freq=2462 MHz)
Fri Nov 5 19:05:52 2021 kern.info kernel: [16473.151223] wlan-sta: authenticate with 04:62:73:29:2a:64
Fri Nov 5 19:05:52 2021 kern.info kernel: [16473.169469] wlan-sta: send auth to 04:62:73:29:2a:64 (try 1/3)
Fri Nov 5 19:05:52 2021 daemon.notice wpa_supplicant[19253]: wlan-sta: Trying to associate with 04:62:73:29:2a:64 (SSID=‘@BayernWLAN ’ freq=2462 MHz)
Fri Nov 5 19:05:52 2021 kern.info kernel: [16473.177326] wlan-sta: authenticated
Fri Nov 5 19:05:52 2021 kern.info kernel: [16473.186183] wlan-sta: associate with 04:62:73:29:2a:64 (try 1/3)
Fri Nov 5 19:05:52 2021 kern.info kernel: [16473.195723] wlan-sta: RX AssocResp from 04:62:73:29:2a:64 (capab=0x1421 status=0 aid=1)
Fri Nov 5 19:05:52 2021 kern.info kernel: [16473.204274] wlan-sta: associated
Fri Nov 5 19:05:52 2021 daemon.notice netifd: Network device ‘wlan-sta’ link is up
Fri Nov 5 19:05:52 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Fri Nov 5 19:05:52 2021 daemon.notice netifd: Interface ‘wwan’ is setting up now
Fri Nov 5 19:05:52 2021 daemon.notice wpa_supplicant[19253]: wlan-sta: Associated with 04:62:73:29:2a:64
Fri Nov 5 19:05:52 2021 daemon.notice wpa_supplicant[19253]: wlan-sta: CTRL-EVENT-CONNECTED - Connection to 04:62:73:29:2a:64 completed [id=0 id_str=]
Fri Nov 5 19:05:52 2021 kern.debug kernel: [16473.236161] wlan-sta: Limiting TX power to 1 dBm as advertised by 04:62:73:29:2a:64
Fri Nov 5 19:05:52 2021 kern.info kernel: [16473.336399] br-lan: port 2(wlan1) entered blocking state
Fri Nov 5 19:05:52 2021 kern.info kernel: [16473.341919] br-lan: port 2(wlan1) entered forwarding state
Fri Nov 5 19:05:52 2021 daemon.notice netifd: Network device ‘wlan1’ link is up
Fri Nov 5 19:05:52 2021 daemon.notice wpa_supplicant[19253]: wlan-sta: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Fri Nov 5 19:05:53 2021 daemon.notice netifd: wwan (19283): udhcpc: started, v1.30.1
Fri Nov 5 19:05:53 2021 daemon.notice netifd: wwan (19283): udhcpc: sending discover
Fri Nov 5 19:05:53 2021 daemon.notice netifd: wwan (19283): udhcpc: sending select for 100.80.8.191
Fri Nov 5 19:05:53 2021 daemon.notice netifd: wwan (19283): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 19:05:53 2021 daemon.notice netifd: Interface ‘wwan’ is now up
Fri Nov 5 19:05:53 2021 daemon.info dnsmasq[2829]: reading /tmp/resolv.conf.auto
Fri Nov 5 19:05:53 2021 daemon.info dnsmasq[2829]: using local addresses only for domain test
Fri Nov 5 19:05:53 2021 daemon.info dnsmasq[2829]: using local addresses only for domain onion
Fri Nov 5 19:05:53 2021 daemon.info dnsmasq[2829]: using local addresses only for domain localhost
Fri Nov 5 19:05:53 2021 daemon.info dnsmasq[2829]: using local addresses only for domain invalid
Fri Nov 5 19:05:53 2021 daemon.info dnsmasq[2829]: using local addresses only for domain bind
Fri Nov 5 19:05:53 2021 daemon.info dnsmasq[2829]: using local addresses only for domain lan
Fri Nov 5 19:05:53 2021 daemon.info dnsmasq[2829]: using nameserver 10.175.177.132#53
Fri Nov 5 19:05:53 2021 daemon.info dnsmasq[2829]: using nameserver 10.175.179.132#53
Fri Nov 5 19:05:54 2021 user.info : [ 817] gl-sdk>> wifi_join return=0, channel=11
Fri Nov 5 19:05:54 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf IEEE 802.11: authenticated
Fri Nov 5 19:05:54 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf IEEE 802.11: associated (aid 1)
Fri Nov 5 19:05:55 2021 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 64:27:37:b5:33:cf
Fri Nov 5 19:05:55 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf RADIUS: starting accounting session B1FE77397878E2B7
Fri Nov 5 19:05:55 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf WPA: pairwise key handshake completed (RSN)
Fri Nov 5 19:05:55 2021 daemon.info dnsmasq-dhcp[2829]: DHCPREQUEST(br-lan) 192.168.8.243 64:27:37:b5:33:cf
Fri Nov 5 19:05:55 2021 daemon.info dnsmasq-dhcp[2829]: DHCPACK(br-lan) 192.168.8.243 64:27:37:b5:33:cf VAIO-Carlo
Fri Nov 5 19:05:57 2021 user.info mwan3rtmon[2641]: Detect rtchange event.
Fri Nov 5 19:05:58 2021 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
Fri Nov 5 19:06:54 2021 user.info : gl_health start->
Fri Nov 5 19:07:17 2021 daemon.info dnsmasq-dhcp[2829]: DHCPINFORM(br-lan) 192.168.8.243 64:27:37:b5:33:cf
Fri Nov 5 19:07:17 2021 daemon.info dnsmasq-dhcp[2829]: DHCPACK(br-lan) 192.168.8.243 64:27:37:b5:33:cf VAIO-Carlo
Fri Nov 5 19:11:51 2021 user.info : gl_health start->
Fri Nov 5 19:13:23 2021 daemon.notice netifd: wwan (19283): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 19:13:23 2021 daemon.notice netifd: wwan (19283): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 19:20:53 2021 daemon.notice netifd: wwan (19283): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 19:20:53 2021 daemon.notice netifd: wwan (19283): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 19:28:23 2021 daemon.notice netifd: wwan (19283): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 19:28:23 2021 daemon.notice netifd: wwan (19283): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 19:29:47 2021 daemon.info dnsmasq-dhcp[2829]: DHCPINFORM(br-lan) 192.168.8.243 64:27:37:b5:33:cf
Fri Nov 5 19:29:47 2021 daemon.info dnsmasq-dhcp[2829]: DHCPACK(br-lan) 192.168.8.243 64:27:37:b5:33:cf VAIO-Carlo
Fri Nov 5 19:32:32 2021 daemon.notice netifd: Interface ‘wwan’ is disabled
Fri Nov 5 19:32:32 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Fri Nov 5 19:32:32 2021 daemon.notice netifd: wwan (19283): udhcpc: received SIGTERM
Fri Nov 5 19:32:32 2021 daemon.notice netifd: Interface ‘wwan’ is now down
Fri Nov 5 19:32:32 2021 daemon.warn dnsmasq[2829]: no servers found in /tmp/resolv.conf.auto, will retry
Fri Nov 5 19:32:33 2021 daemon.notice hostapd: wlan0: interface state ENABLED->DISABLED
Fri Nov 5 19:32:33 2021 daemon.notice hostapd: wlan0: AP-DISABLED
Fri Nov 5 19:32:33 2021 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Fri Nov 5 19:32:33 2021 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Fri Nov 5 19:32:33 2021 kern.info kernel: [18073.477579] device wlan0 left promiscuous mode
Fri Nov 5 19:32:33 2021 kern.info kernel: [18073.482374] br-lan: port 3(wlan0) entered disabled state
Fri Nov 5 19:32:33 2021 daemon.notice netifd: Network device ‘wlan0’ link is down
Fri Nov 5 19:32:33 2021 daemon.notice hostapd: wlan1: interface state ENABLED->DISABLED
Fri Nov 5 19:32:33 2021 daemon.notice hostapd: wlan1: AP-STA-DISCONNECTED 64:27:37:b5:33:cf
Fri Nov 5 19:32:33 2021 daemon.notice hostapd: wlan1: AP-DISABLED
Fri Nov 5 19:32:33 2021 daemon.notice hostapd: wlan1: CTRL-EVENT-TERMINATING
Fri Nov 5 19:32:33 2021 daemon.notice hostapd: nl80211: deinit ifname=wlan1 disabled_11b_rates=0
Fri Nov 5 19:32:33 2021 kern.info kernel: [18073.663464] wlan-sta: deauthenticating from 04:62:73:29:2a:64 by local choice (Reason: 3=DEAUTH_LEAVING)
Fri Nov 5 19:32:33 2021 kern.info kernel: [18073.722156] device wlan1 left promiscuous mode
Fri Nov 5 19:32:33 2021 kern.info kernel: [18073.726821] br-lan: port 2(wlan1) entered disabled state
Fri Nov 5 19:32:33 2021 daemon.notice wpa_supplicant[19253]: wlan-sta: CTRL-EVENT-DISCONNECTED bssid=04:62:73:29:2a:64 reason=3 locally_generated=1
Fri Nov 5 19:32:33 2021 daemon.err wpa_supplicant[19253]: Failed to stop hostapd AP interfaces
Fri Nov 5 19:32:33 2021 daemon.notice wpa_supplicant[19253]: nl80211: deinit ifname=wlan-sta disabled_11b_rates=0
Fri Nov 5 19:32:33 2021 daemon.notice wpa_supplicant[19253]: wlan-sta: CTRL-EVENT-TERMINATING
Fri Nov 5 19:32:33 2021 daemon.notice netifd: Network device ‘wlan1’ link is down
Fri Nov 5 19:32:35 2021 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Fri Nov 5 19:32:38 2021 kern.warn kernel: [18078.544396] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
Fri Nov 5 19:32:38 2021 daemon.notice netifd: radio0 (23163): sh: /usr/bin/ovs-vsctl: not found
Fri Nov 5 19:32:38 2021 kern.info kernel: [18078.664968] br-lan: port 2(wlan0) entered blocking state
Fri Nov 5 19:32:38 2021 kern.info kernel: [18078.670494] br-lan: port 2(wlan0) entered disabled state
Fri Nov 5 19:32:38 2021 kern.info kernel: [18078.676268] device wlan0 entered promiscuous mode
Fri Nov 5 19:32:38 2021 daemon.notice hostapd: ACS: Automatic channel selection started, this may take a bit
Fri Nov 5 19:32:38 2021 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->ACS
Fri Nov 5 19:32:38 2021 daemon.notice hostapd: wlan0: ACS-STARTED
Fri Nov 5 19:32:39 2021 daemon.err hostapd: Configuration file: /var/run/hostapd-phy1.conf
Fri Nov 5 19:32:39 2021 daemon.notice netifd: radio1 (23203): sh: /usr/bin/ovs-vsctl: not found
Fri Nov 5 19:32:39 2021 kern.info kernel: [18079.764063] br-lan: port 3(wlan1) entered blocking state
Fri Nov 5 19:32:39 2021 kern.info kernel: [18079.769662] br-lan: port 3(wlan1) entered disabled state
Fri Nov 5 19:32:39 2021 kern.info kernel: [18079.775522] device wlan1 entered promiscuous mode
Fri Nov 5 19:32:39 2021 daemon.err hostapd: Using interface wlan1 with hwaddr 94:83:c4:0e:3c:e6 and ssid “GL-AR750S-xxx”
Fri Nov 5 19:32:39 2021 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->ENABLED
Fri Nov 5 19:32:39 2021 daemon.notice hostapd: wlan1: AP-ENABLED
Fri Nov 5 19:32:39 2021 daemon.notice hostapd: handle_probe_req: send failed
Fri Nov 5 19:32:40 2021 daemon.notice wpa_supplicant[23784]: Successfully initialized wpa_supplicant
Fri Nov 5 19:32:40 2021 daemon.notice netifd: Interface ‘wwan’ is enabled
Fri Nov 5 19:32:41 2021 daemon.notice wpa_supplicant[23792]: wlan-sta: SME: Trying to authenticate with 04:62:73:29:2a:64 (SSID=‘@BayernWLAN ’ freq=2462 MHz)
Fri Nov 5 19:32:41 2021 kern.info kernel: [18081.466812] wlan-sta: authenticate with 04:62:73:29:2a:64
Fri Nov 5 19:32:41 2021 kern.info kernel: [18081.485351] wlan-sta: send auth to 04:62:73:29:2a:64 (try 1/3)
Fri Nov 5 19:32:41 2021 daemon.notice wpa_supplicant[23792]: wlan-sta: Trying to associate with 04:62:73:29:2a:64 (SSID=‘@BayernWLAN ’ freq=2462 MHz)
Fri Nov 5 19:32:41 2021 kern.info kernel: [18081.493599] wlan-sta: authenticated
Fri Nov 5 19:32:41 2021 kern.info kernel: [18081.501644] wlan-sta: associate with 04:62:73:29:2a:64 (try 1/3)
Fri Nov 5 19:32:41 2021 kern.info kernel: [18081.510991] wlan-sta: RX AssocResp from 04:62:73:29:2a:64 (capab=0x1421 status=0 aid=1)
Fri Nov 5 19:32:41 2021 kern.info kernel: [18081.519554] wlan-sta: associated
Fri Nov 5 19:32:41 2021 daemon.notice netifd: Network device ‘wlan-sta’ link is up
Fri Nov 5 19:32:41 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Fri Nov 5 19:32:41 2021 daemon.notice netifd: Interface ‘wwan’ is setting up now
Fri Nov 5 19:32:41 2021 daemon.notice wpa_supplicant[23792]: wlan-sta: Associated with 04:62:73:29:2a:64
Fri Nov 5 19:32:41 2021 daemon.notice wpa_supplicant[23792]: wlan-sta: CTRL-EVENT-CONNECTED - Connection to 04:62:73:29:2a:64 completed [id=0 id_str=]
Fri Nov 5 19:32:41 2021 daemon.notice netifd: Network device ‘wlan1’ link is up
Fri Nov 5 19:32:41 2021 kern.info kernel: [18081.678139] br-lan: port 3(wlan1) entered blocking state
Fri Nov 5 19:32:41 2021 kern.info kernel: [18081.683710] br-lan: port 3(wlan1) entered forwarding state
Fri Nov 5 19:32:41 2021 daemon.notice wpa_supplicant[23792]: wlan-sta: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Fri Nov 5 19:32:41 2021 kern.debug kernel: [18081.712167] wlan-sta: Limiting TX power to 1 dBm as advertised by 04:62:73:29:2a:64
Fri Nov 5 19:32:41 2021 daemon.notice netifd: wwan (23860): udhcpc: started, v1.30.1
Fri Nov 5 19:32:41 2021 daemon.notice netifd: wwan (23860): udhcpc: sending discover
Fri Nov 5 19:32:41 2021 daemon.notice netifd: wwan (23860): udhcpc: sending select for 100.80.8.191
Fri Nov 5 19:32:41 2021 daemon.notice netifd: wwan (23860): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 19:32:41 2021 daemon.notice netifd: Interface ‘wwan’ is now up
Fri Nov 5 19:32:41 2021 daemon.info dnsmasq[2829]: reading /tmp/resolv.conf.auto
Fri Nov 5 19:32:41 2021 daemon.info dnsmasq[2829]: using local addresses only for domain test
Fri Nov 5 19:32:41 2021 daemon.info dnsmasq[2829]: using local addresses only for domain onion
Fri Nov 5 19:32:41 2021 daemon.info dnsmasq[2829]: using local addresses only for domain localhost
Fri Nov 5 19:32:41 2021 daemon.info dnsmasq[2829]: using local addresses only for domain invalid
Fri Nov 5 19:32:41 2021 daemon.info dnsmasq[2829]: using local addresses only for domain bind
Fri Nov 5 19:32:41 2021 daemon.info dnsmasq[2829]: using local addresses only for domain lan
Fri Nov 5 19:32:41 2021 daemon.info dnsmasq[2829]: using nameserver 10.175.177.132#53
Fri Nov 5 19:32:41 2021 daemon.info dnsmasq[2829]: using nameserver 10.175.179.132#53
Fri Nov 5 19:32:44 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf IEEE 802.11: authenticated
Fri Nov 5 19:32:44 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf IEEE 802.11: associated (aid 1)
Fri Nov 5 19:32:44 2021 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 64:27:37:b5:33:cf
Fri Nov 5 19:32:44 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf RADIUS: starting accounting session 650DF2BE613B8047
Fri Nov 5 19:32:44 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf WPA: pairwise key handshake completed (RSN)
Fri Nov 5 19:32:44 2021 daemon.info dnsmasq-dhcp[2829]: DHCPREQUEST(br-lan) 192.168.8.243 64:27:37:b5:33:cf
Fri Nov 5 19:32:44 2021 daemon.info dnsmasq-dhcp[2829]: DHCPACK(br-lan) 192.168.8.243 64:27:37:b5:33:cf VAIO-Carlo
Fri Nov 5 19:32:45 2021 daemon.notice hostapd: wlan0: ACS-COMPLETED freq=5180 channel=36
Fri Nov 5 19:32:45 2021 daemon.notice hostapd: wlan0: interface state ACS->HT_SCAN
Fri Nov 5 19:32:45 2021 daemon.err hostapd: Using interface wlan0 with hwaddr 94:83:c4:0e:3c:e7 and ssid “GL-AR750S-xxx-5G”
Fri Nov 5 19:32:45 2021 daemon.notice hostapd: wlan0: interface state HT_SCAN->ENABLED
Fri Nov 5 19:32:45 2021 kern.info kernel: [18086.167022] br-lan: port 2(wlan0) entered blocking state
Fri Nov 5 19:32:45 2021 kern.info kernel: [18086.172577] br-lan: port 2(wlan0) entered forwarding state
Fri Nov 5 19:32:45 2021 daemon.notice hostapd: wlan0: AP-ENABLED
Fri Nov 5 19:32:46 2021 daemon.notice netifd: Network device ‘wlan0’ link is up
Fri Nov 5 19:32:46 2021 user.info mwan3rtmon[2641]: Detect rtchange event.
Fri Nov 5 19:32:47 2021 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
Fri Nov 5 19:33:08 2021 user.info : saved ssid ignore: @BayernWLAN 0
Fri Nov 5 19:33:08 2021 user.info : [ 810] gl-sdk>> bIsSaved=0, ssid=@BayernWLAN, encryption=none, bssid=00:81:C4:7C:69:C4, wds=0, device=radio1, identity=, channel=1
Fri Nov 5 19:33:08 2021 user.info : [ 3043] gl-wifi-core>> bIsStaEnabled=1
Fri Nov 5 19:33:08 2021 daemon.notice netifd: Interface ‘wwan’ is disabled
Fri Nov 5 19:33:08 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Fri Nov 5 19:33:08 2021 daemon.notice netifd: wwan (23860): udhcpc: received SIGTERM
Fri Nov 5 19:33:08 2021 daemon.notice netifd: Interface ‘wwan’ is now down
Fri Nov 5 19:33:09 2021 daemon.warn dnsmasq[2829]: no servers found in /tmp/resolv.conf.auto, will retry
Fri Nov 5 19:33:09 2021 daemon.notice hostapd: wlan1: interface state ENABLED->DISABLED
Fri Nov 5 19:33:09 2021 daemon.notice hostapd: wlan1: AP-STA-DISCONNECTED 64:27:37:b5:33:cf
Fri Nov 5 19:33:09 2021 daemon.notice hostapd: wlan1: AP-DISABLED
Fri Nov 5 19:33:09 2021 daemon.notice hostapd: wlan1: CTRL-EVENT-TERMINATING
Fri Nov 5 19:33:09 2021 daemon.notice hostapd: nl80211: deinit ifname=wlan1 disabled_11b_rates=0
Fri Nov 5 19:33:09 2021 kern.info kernel: [18109.469993] wlan-sta: deauthenticating from 04:62:73:29:2a:64 by local choice (Reason: 3=DEAUTH_LEAVING)
Fri Nov 5 19:33:09 2021 kern.info kernel: [18109.490742] device wlan1 left promiscuous mode
Fri Nov 5 19:33:09 2021 kern.info kernel: [18109.495488] br-lan: port 3(wlan1) entered disabled state
Fri Nov 5 19:33:09 2021 daemon.notice wpa_supplicant[23792]: wlan-sta: CTRL-EVENT-DISCONNECTED bssid=04:62:73:29:2a:64 reason=3 locally_generated=1
Fri Nov 5 19:33:09 2021 daemon.err wpa_supplicant[23792]: Failed to stop hostapd AP interfaces
Fri Nov 5 19:33:09 2021 daemon.notice wpa_supplicant[23792]: nl80211: deinit ifname=wlan-sta disabled_11b_rates=0
Fri Nov 5 19:33:09 2021 daemon.notice wpa_supplicant[23792]: wlan-sta: CTRL-EVENT-TERMINATING
Fri Nov 5 19:33:09 2021 daemon.notice netifd: Network device ‘wlan1’ link is down
Fri Nov 5 19:33:12 2021 daemon.err hostapd: Configuration file: /var/run/hostapd-phy1.conf
Fri Nov 5 19:33:12 2021 daemon.notice netifd: radio1 (25131): sh: /usr/bin/ovs-vsctl: not found
Fri Nov 5 19:33:12 2021 kern.info kernel: [18112.802731] br-lan: port 3(wlan1) entered blocking state
Fri Nov 5 19:33:12 2021 kern.info kernel: [18112.808435] br-lan: port 3(wlan1) entered disabled state
Fri Nov 5 19:33:12 2021 kern.info kernel: [18112.814289] device wlan1 entered promiscuous mode
Fri Nov 5 19:33:12 2021 daemon.err hostapd: Using interface wlan1 with hwaddr 94:83:c4:0e:3c:e6 and ssid “GL-AR750S-xxx”
Fri Nov 5 19:33:12 2021 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->ENABLED
Fri Nov 5 19:33:12 2021 daemon.notice hostapd: wlan1: AP-ENABLED
Fri Nov 5 19:33:13 2021 daemon.notice wpa_supplicant[25573]: Successfully initialized wpa_supplicant
Fri Nov 5 19:33:13 2021 daemon.notice hostapd: handle_probe_req: send failed
Fri Nov 5 19:33:13 2021 daemon.notice netifd: Interface ‘wwan’ is enabled
Fri Nov 5 19:33:14 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: SME: Trying to authenticate with 00:81:c4:7c:69:c4 (SSID=‘@BayernWLAN ’ freq=2412 MHz)
Fri Nov 5 19:33:14 2021 kern.info kernel: [18114.907915] wlan-sta: authenticate with 00:81:c4:7c:69:c4
Fri Nov 5 19:33:14 2021 kern.info kernel: [18114.926319] wlan-sta: send auth to 00:81:c4:7c:69:c4 (try 1/3)
Fri Nov 5 19:33:14 2021 kern.info kernel: [18115.041469] wlan-sta: send auth to 00:81:c4:7c:69:c4 (try 2/3)
Fri Nov 5 19:33:14 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: Trying to associate with 00:81:c4:7c:69:c4 (SSID=‘@BayernWLAN ’ freq=2412 MHz)
Fri Nov 5 19:33:14 2021 kern.info kernel: [18115.051649] wlan-sta: authenticated
Fri Nov 5 19:33:14 2021 kern.info kernel: [18115.061620] wlan-sta: associate with 00:81:c4:7c:69:c4 (try 1/3)
Fri Nov 5 19:33:14 2021 kern.info kernel: [18115.081122] wlan-sta: RX AssocResp from 00:81:c4:7c:69:c4 (capab=0x1421 status=0 aid=2)
Fri Nov 5 19:33:14 2021 kern.info kernel: [18115.089691] wlan-sta: associated
Fri Nov 5 19:33:14 2021 kern.debug kernel: [18115.093387] wlan-sta: Limiting TX power to 4 dBm as advertised by 00:81:c4:7c:69:c4
Fri Nov 5 19:33:14 2021 daemon.notice netifd: Network device ‘wlan-sta’ link is up
Fri Nov 5 19:33:14 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Fri Nov 5 19:33:14 2021 daemon.notice netifd: Interface ‘wwan’ is setting up now
Fri Nov 5 19:33:14 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: Associated with 00:81:c4:7c:69:c4
Fri Nov 5 19:33:14 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-CONNECTED - Connection to 00:81:c4:7c:69:c4 completed [id=0 id_str=]
Fri Nov 5 19:33:14 2021 kern.info kernel: [18115.309357] br-lan: port 3(wlan1) entered blocking state
Fri Nov 5 19:33:14 2021 kern.info kernel: [18115.314926] br-lan: port 3(wlan1) entered forwarding state
Fri Nov 5 19:33:14 2021 daemon.notice netifd: Network device ‘wlan1’ link is up
Fri Nov 5 19:33:14 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Fri Nov 5 19:33:15 2021 daemon.notice netifd: wwan (25678): udhcpc: started, v1.30.1
Fri Nov 5 19:33:15 2021 daemon.notice netifd: wwan (25678): udhcpc: sending discover
Fri Nov 5 19:33:15 2021 daemon.notice netifd: wwan (25678): udhcpc: sending select for 100.80.8.191
Fri Nov 5 19:33:15 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 19:33:15 2021 daemon.notice netifd: Interface ‘wwan’ is now up
Fri Nov 5 19:33:15 2021 daemon.info dnsmasq[2829]: reading /tmp/resolv.conf.auto
Fri Nov 5 19:33:15 2021 daemon.info dnsmasq[2829]: using local addresses only for domain test
Fri Nov 5 19:33:15 2021 daemon.info dnsmasq[2829]: using local addresses only for domain onion
Fri Nov 5 19:33:15 2021 daemon.info dnsmasq[2829]: using local addresses only for domain localhost
Fri Nov 5 19:33:15 2021 daemon.info dnsmasq[2829]: using local addresses only for domain invalid
Fri Nov 5 19:33:15 2021 daemon.info dnsmasq[2829]: using local addresses only for domain bind
Fri Nov 5 19:33:15 2021 daemon.info dnsmasq[2829]: using local addresses only for domain lan
Fri Nov 5 19:33:15 2021 daemon.info dnsmasq[2829]: using nameserver 10.175.177.132#53
Fri Nov 5 19:33:15 2021 daemon.info dnsmasq[2829]: using nameserver 10.175.179.132#53
Fri Nov 5 19:33:16 2021 user.info : [ 817] gl-sdk>> wifi_join return=0, channel=1
Fri Nov 5 19:33:16 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf IEEE 802.11: authenticated
Fri Nov 5 19:33:16 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf IEEE 802.11: associated (aid 1)
Fri Nov 5 19:33:16 2021 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 64:27:37:b5:33:cf
Fri Nov 5 19:33:16 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf RADIUS: starting accounting session 874AE39E5CE178AD
Fri Nov 5 19:33:16 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf WPA: pairwise key handshake completed (RSN)
Fri Nov 5 19:33:17 2021 daemon.info dnsmasq-dhcp[2829]: DHCPREQUEST(br-lan) 192.168.8.243 64:27:37:b5:33:cf
Fri Nov 5 19:33:17 2021 daemon.info dnsmasq-dhcp[2829]: DHCPACK(br-lan) 192.168.8.243 64:27:37:b5:33:cf VAIO-Carlo
Fri Nov 5 19:33:20 2021 user.info mwan3rtmon[2641]: Detect rtchange event.
Fri Nov 5 19:33:21 2021 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
Fri Nov 5 19:40:45 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 19:40:45 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 19:44:24 2021 daemon.info dnsmasq-dhcp[2829]: DHCPINFORM(br-lan) 192.168.8.243 64:27:37:b5:33:cf
Fri Nov 5 19:44:24 2021 daemon.info dnsmasq-dhcp[2829]: DHCPACK(br-lan) 192.168.8.243 64:27:37:b5:33:cf VAIO-Carlo
Fri Nov 5 19:48:15 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 19:48:15 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 19:55:45 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 19:55:45 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 19:59:47 2021 daemon.info dnsmasq-dhcp[2829]: DHCPINFORM(br-lan) 192.168.8.243 64:27:37:b5:33:cf
Fri Nov 5 19:59:47 2021 daemon.info dnsmasq-dhcp[2829]: DHCPACK(br-lan) 192.168.8.243 64:27:37:b5:33:cf VAIO-Carlo
Fri Nov 5 20:03:15 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 20:03:15 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 20:10:45 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 20:10:45 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 20:14:47 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:14:59 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:15:03 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:15:04 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:15:08 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:15:11 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:15:13 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:15:22 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:15:24 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:15:34 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:15:36 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:16:16 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:18:15 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 20:18:15 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 20:18:23 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:18:28 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:19:22 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:19:53 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:19:57 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:20:07 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:20:11 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:20:15 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:20:16 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:20:17 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:20:18 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:20:19 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:25:45 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 20:25:45 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 20:29:47 2021 daemon.info dnsmasq-dhcp[2829]: DHCPINFORM(br-lan) 192.168.8.243 64:27:37:b5:33:cf
Fri Nov 5 20:29:47 2021 daemon.info dnsmasq-dhcp[2829]: DHCPACK(br-lan) 192.168.8.243 64:27:37:b5:33:cf VAIO-Carlo
Fri Nov 5 20:31:20 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:31:33 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:33:15 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 20:33:15 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 20:34:10 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 20:40:45 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 20:40:45 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 20:48:15 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 20:48:15 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 20:55:45 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 20:55:45 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 20:59:47 2021 daemon.info dnsmasq-dhcp[2829]: DHCPINFORM(br-lan) 192.168.8.243 64:27:37:b5:33:cf
Fri Nov 5 20:59:47 2021 daemon.info dnsmasq-dhcp[2829]: DHCPACK(br-lan) 192.168.8.243 64:27:37:b5:33:cf VAIO-Carlo
Fri Nov 5 21:03:15 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 21:03:15 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 21:10:45 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 21:10:45 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 21:18:16 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 21:18:16 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 21:25:46 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 21:25:46 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 21:29:47 2021 daemon.info dnsmasq-dhcp[2829]: DHCPINFORM(br-lan) 192.168.8.243 64:27:37:b5:33:cf
Fri Nov 5 21:29:47 2021 daemon.info dnsmasq-dhcp[2829]: DHCPACK(br-lan) 192.168.8.243 64:27:37:b5:33:cf VAIO-Carlo
Fri Nov 5 21:33:16 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 21:33:16 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 21:36:04 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 21:36:39 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 21:36:49 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 21:37:00 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 21:37:06 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 21:37:16 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 21:37:32 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 21:40:46 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 21:40:46 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 21:48:16 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 21:48:16 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 21:55:46 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 21:55:46 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 21:59:47 2021 daemon.info dnsmasq-dhcp[2829]: DHCPINFORM(br-lan) 192.168.8.243 64:27:37:b5:33:cf
Fri Nov 5 21:59:47 2021 daemon.info dnsmasq-dhcp[2829]: DHCPACK(br-lan) 192.168.8.243 64:27:37:b5:33:cf VAIO-Carlo
Fri Nov 5 22:00:45 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 22:03:16 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 22:03:16 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 22:10:46 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 22:10:46 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 22:14:06 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 22:18:16 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 22:18:16 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 22:20:42 2021 daemon.info dnsmasq-dhcp[2829]: DHCPINFORM(br-lan) 192.168.8.243 64:27:37:b5:33:cf
Fri Nov 5 22:20:42 2021 daemon.info dnsmasq-dhcp[2829]: DHCPACK(br-lan) 192.168.8.243 64:27:37:b5:33:cf VAIO-Carlo
Fri Nov 5 22:25:46 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 22:25:46 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 22:26:42 2021 daemon.info dnsmasq-dhcp[2829]: DHCPINFORM(br-lan) 192.168.8.243 64:27:37:b5:33:cf
Fri Nov 5 22:26:42 2021 daemon.info dnsmasq-dhcp[2829]: DHCPACK(br-lan) 192.168.8.243 64:27:37:b5:33:cf VAIO-Carlo
Fri Nov 5 22:29:47 2021 daemon.info dnsmasq-dhcp[2829]: DHCPINFORM(br-lan) 192.168.8.243 64:27:37:b5:33:cf
Fri Nov 5 22:29:47 2021 daemon.info dnsmasq-dhcp[2829]: DHCPACK(br-lan) 192.168.8.243 64:27:37:b5:33:cf VAIO-Carlo
Fri Nov 5 22:33:16 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 22:33:16 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 22:34:34 2021 daemon.info dnsmasq-dhcp[2829]: DHCPINFORM(br-lan) 192.168.8.243 64:27:37:b5:33:cf
Fri Nov 5 22:34:34 2021 daemon.info dnsmasq-dhcp[2829]: DHCPACK(br-lan) 192.168.8.243 64:27:37:b5:33:cf VAIO-Carlo
Fri Nov 5 22:35:50 2021 daemon.info dnsmasq-dhcp[2829]: DHCPINFORM(br-lan) 192.168.8.243 64:27:37:b5:33:cf
Fri Nov 5 22:35:50 2021 daemon.info dnsmasq-dhcp[2829]: DHCPACK(br-lan) 192.168.8.243 64:27:37:b5:33:cf VAIO-Carlo
Fri Nov 5 22:36:03 2021 authpriv.info dropbear[4628]: Child connection from 192.168.8.243:42425
Fri Nov 5 22:36:09 2021 authpriv.info dropbear[4628]: Exit before auth: Exited normally
Fri Nov 5 22:40:46 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 22:40:47 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 22:45:50 2021 daemon.info dnsmasq-dhcp[2829]: DHCPINFORM(br-lan) 192.168.8.243 64:27:37:b5:33:cf
Fri Nov 5 22:45:50 2021 daemon.info dnsmasq-dhcp[2829]: DHCPACK(br-lan) 192.168.8.243 64:27:37:b5:33:cf VAIO-Carlo
Fri Nov 5 22:48:17 2021 daemon.notice netifd: wwan (25678): udhcpc: sending renew to 192.0.2.1
Fri Nov 5 22:48:17 2021 daemon.notice netifd: wwan (25678): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 22:53:26 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 22:53:30 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 22:54:02 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 22:54:28 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 22:54:29 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 22:54:38 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 22:54:39 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 22:54:41 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 22:54:43 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 22:55:21 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Fri Nov 5 22:55:21 2021 daemon.notice netifd: Network device ‘wlan-sta’ link is down
Fri Nov 5 22:55:21 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Fri Nov 5 22:55:21 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-DISCONNECTED bssid=00:81:c4:7c:69:c4 reason=4 locally_generated=1
Fri Nov 5 22:55:21 2021 daemon.notice netifd: wwan (25678): udhcpc: received SIGTERM
Fri Nov 5 22:55:21 2021 daemon.notice netifd: Interface ‘wwan’ is now down
Fri Nov 5 22:55:21 2021 daemon.notice netifd: Interface ‘wwan’ is disabled
Fri Nov 5 22:55:21 2021 daemon.notice netifd: Interface ‘wwan’ is enabled
Fri Nov 5 22:55:21 2021 daemon.warn dnsmasq[2829]: no servers found in /tmp/resolv.conf.auto, will retry
Fri Nov 5 22:55:22 2021 daemon.notice netifd: Network device ‘wlan1’ link is down
Fri Nov 5 22:55:22 2021 kern.info kernel: [30243.096122] br-lan: port 3(wlan1) entered disabled state
Fri Nov 5 22:55:24 2021 daemon.notice hostapd: handle_probe_req: send failed
Fri Nov 5 22:55:25 2021 daemon.notice hostapd: handle_probe_req: send failed
Fri Nov 5 22:55:26 2021 daemon.notice hostapd: handle_probe_req: send failed
Fri Nov 5 22:55:26 2021 daemon.notice netifd: Network device ‘wlan1’ link is up
Fri Nov 5 22:55:26 2021 kern.info kernel: [30246.601062] br-lan: port 3(wlan1) entered blocking state
Fri Nov 5 22:55:26 2021 kern.info kernel: [30246.606626] br-lan: port 3(wlan1) entered forwarding state
Fri Nov 5 22:55:26 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: SME: Trying to authenticate with 00:81:c4:7c:69:c4 (SSID=‘@BayernWLAN ’ freq=2412 MHz)
Fri Nov 5 22:55:26 2021 kern.info kernel: [30246.869058] wlan-sta: authenticate with 00:81:c4:7c:69:c4
Fri Nov 5 22:55:26 2021 kern.info kernel: [30246.875005] wlan-sta: send auth to 00:81:c4:7c:69:c4 (try 1/3)
Fri Nov 5 22:55:26 2021 daemon.notice hostapd: wlan1: AP-STA-DISCONNECTED 64:27:37:b5:33:cf
Fri Nov 5 22:55:26 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf IEEE 802.11: authenticated
Fri Nov 5 22:55:26 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf IEEE 802.11: associated (aid 1)
Fri Nov 5 22:55:26 2021 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 64:27:37:b5:33:cf
Fri Nov 5 22:55:26 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf RADIUS: starting accounting session 874AE39E5CE178AD
Fri Nov 5 22:55:26 2021 daemon.info hostapd: wlan1: STA 64:27:37:b5:33:cf WPA: pairwise key handshake completed (RSN)
Fri Nov 5 22:55:26 2021 daemon.info dnsmasq-dhcp[2829]: DHCPREQUEST(br-lan) 192.168.8.243 64:27:37:b5:33:cf
Fri Nov 5 22:55:26 2021 daemon.info dnsmasq-dhcp[2829]: DHCPACK(br-lan) 192.168.8.243 64:27:37:b5:33:cf VAIO-Carlo
Fri Nov 5 22:55:26 2021 kern.info kernel: [30247.086037] wlan-sta: send auth to 00:81:c4:7c:69:c4 (try 2/3)
Fri Nov 5 22:55:26 2021 kern.info kernel: [30247.093457] wlan-sta: authenticated
Fri Nov 5 22:55:26 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: Trying to associate with 00:81:c4:7c:69:c4 (SSID=‘@BayernWLAN ’ freq=2412 MHz)
Fri Nov 5 22:55:26 2021 kern.info kernel: [30247.106085] wlan-sta: associate with 00:81:c4:7c:69:c4 (try 1/3)
Fri Nov 5 22:55:26 2021 daemon.notice netifd: Network device ‘wlan-sta’ link is up
Fri Nov 5 22:55:26 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Fri Nov 5 22:55:26 2021 daemon.notice netifd: Interface ‘wwan’ is setting up now
Fri Nov 5 22:55:26 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: Associated with 00:81:c4:7c:69:c4
Fri Nov 5 22:55:26 2021 kern.info kernel: [30247.118982] wlan-sta: RX AssocResp from 00:81:c4:7c:69:c4 (capab=0x1421 status=0 aid=2)
Fri Nov 5 22:55:26 2021 kern.info kernel: [30247.127533] wlan-sta: associated
Fri Nov 5 22:55:26 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-CONNECTED - Connection to 00:81:c4:7c:69:c4 completed [id=0 id_str=]
Fri Nov 5 22:55:26 2021 kern.debug kernel: [30247.178596] wlan-sta: Limiting TX power to 4 dBm as advertised by 00:81:c4:7c:69:c4
Fri Nov 5 22:55:26 2021 daemon.notice wpa_supplicant[25589]: wlan-sta: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Fri Nov 5 22:55:26 2021 daemon.notice netifd: wwan (30702): udhcpc: started, v1.30.1
Fri Nov 5 22:55:27 2021 daemon.notice netifd: wwan (30702): udhcpc: sending discover
Fri Nov 5 22:55:27 2021 daemon.notice netifd: wwan (30702): udhcpc: sending select for 100.80.8.191
Fri Nov 5 22:55:27 2021 daemon.notice netifd: wwan (30702): udhcpc: lease of 100.80.8.191 obtained, lease time 900
Fri Nov 5 22:55:27 2021 daemon.notice netifd: Interface ‘wwan’ is now up
Fri Nov 5 22:55:27 2021 daemon.info dnsmasq[2829]: reading /tmp/resolv.conf.auto
alzhao
November 7, 2021, 7:16am
#8
The DHCP release is 900 seconds, i.e. 15 minutes. The router need to renew dhcp every 7 minutes. So doe your network just break every 7 minutes?
Hi alzhao,
first of all, I apologize for the time taken to respond; I should have moved to Italy, but due to two unforeseen operations for detachment of the retina I am currently in Germany, being hosted by a friend.
My response times are therefore related to visual difficulties.
Coming to your answer, it could be, but it seems to me I dind’t experience obvious disconnections when I was briwsing.
As I said the log refers to a free WI-FI connection available in another city (capital München) than the one where I had the reported problems (Passau).
In München I didn’t have problems with the Slate WI-FI connections and regarding to the disconnections with Whatsapp I can only report their lower frequency.
However, since this did not happen when I connected the phone directly to both free networks, I easily deduced that the problem did not lie in a technical choice of the network managers, but in some hardware / software aspect of the router.
I would try to test the router with my friend WI-FI, but unfortunately my friend’s internet connection is somewhat unstable and manifests several daily disconnections (Germans are far from perfect … ;-).
At this point, if there are no particular advice, I would close the post, referring to a next one when I will be able to provide more detailed data.
Thanks
alzhao
November 16, 2021, 2:55am
#10
OK. Thanks for the feedback. Keep me posted.
