I may have accidentally installed firmware 4 on my AR750S-Ext, the one from here:
I don’t seem to be able to use U-Boot now and am kind of lost on how to go back to firmware 3.
Can anyone help?
Can anyone help?
Thanks but no.
U-Boot is not loading, no other reset option helps, also revert firmware does not do anything
I don’t know what U-Boot mean, so wait a little bit for the gl support.
Can you SSH to the router?
If yes, use scp
command to copy firmware 3.x file to router, then use sysupgrade
command to upgrade.
sysupgrade openwrt-ar750s-3.203-0701.tar
