Hello, I see that this sdk for vlan gl-sdk4-ui-vlan is installed but I do not see any function related to vlan in the webadmin.
Is that correct or is something missing in the AR750S webadmin not showing any vlan window config?
Thanks.
Thanks.
VLAN isn’t supported by main GUI (only VLAN for PPPoE so far) - so this is alright.
OK thank you for your quick answer.
Bye.
