AR750S - FW 4.3.11 - Missing package gl-sdk4-cloud
Hello. I have unintentionally uninstalled the goodcloud sdk4 and I cannot find it in the repository list.
It seems to me that it was gl-sdk4-cloud and gl-sdk4-ui-cloud.
Thanks
Maybe just reset the firmware.
There is no way to download manually as .ipk ?
As it is pre-installed in the router, guys didn’t put in the software repo.
Also pls note, you cannot really remove ipk from the router. It is just hidden. I am not sure if it will cause troubles if you install again.
If you are happy the ipk is still there. Maybe try
find /rom | grep <ipkname>
ok I will give a look. Never done this but it’s ok better than reinstall FW.
Thanks
It‘s worth a try :slight_smile:
find /rom | grep gl-sdk4-cloud
