Hello!
I want to know, if it is possible to do this, the commands to make easier to select one or other WISP configured in Luci by using the Switch Button. I only connect to 2 available WIFI networks so I have to go Luci and Disable one network in Wireless menu and Enable the other. Also can I configure time (seconds) to allow for one network to shut down and the other to wake up?
Can I make this with the Switch Button?
Thx.
