The keywords “ar750s openvpn speed” come up with 0 relevant results, so new post. Upgraded to the ar750s from the ar300m for a better radio and a cpu bump for openvpn. Openvpn on the computer results in 20 Mbps, was getting a rock solid 6-9 Mbps openvpn on the ar300m, getting 3-10 Mbps on the ar750s, all over the place. This seems like a very small iffy bump, what numbers/performace should I be expecting?
The ar750s uses a QCA9563, @775MHz SoC CPU where the ar300m uses a QCA9531, @650MHz SoC CPU, so the ar750s CPU is not really that much better then the ar300m. You can find GL iNet’s rated OpenVPN and Wireguard speeds for each device at:
I have never reach these rates on my tests on my ar750s or ar300m. I am assuming these are best rates seen in a controlled lab environment.
Right, makes sense. Thank you. While the OpenVPN speeds are on the slow side, the connection is rock solid & software is well done; really impressive. Unless the Beryl is rocking 15-20Mbps real numbers, the best size-to-performance ratio for OpenVPN is the ar750 for sure.
16Mbps is not bad. Probably a better upgrade path to go from the ar300m to a beryl with those numbers. frivpn will be retroactive awesome-ness someday.
