Hi everyone!
I have an AR750S router that I want to use to connect two different lans. Here is my current configuration:
I configured the vlans like this:
Port 1 = Lan1(untagged) / Lan2(untagged) / Wan(off)
Port 2 = Lan1(off) / Lan2 (off) / Wan(untagged)
My problem is as follows:
If I connect to my router via wifi with a PC addressed 10.x.x.x.x / 8 I can communicate with my different PCs and I can access the router interface at address 10.0.0.0.1.
On the other hand, if I connect to my router via wifi with a PC addressed in 192.168.8.x / 24, it is impossible to ping anyone or access my router configuration interface (192.168.8.1).
Where did I go wrong? Does anyone have an idea to use the router’s wifi for 2 different addressing VLANs?
Is it a firewall problem?
Thank you for your help!
