Aria2 On 2.20 not supporting torrent! what should i do
Aria2 On 2.20 not supporting torrent! what should i do help me
anyway to downgrade? the aria2c
I’ve never heard of Aria2 but downgrading it is possible executing this command in a shell: opkg --force-downgrade aria2c
To open a shell on Windows and downgrade aria2c:
Make sure you allready have installed the router usign the setup page.
  1. Download putty.exe (https://the.earth.li/~sgtatham/putty/latest/x86/putty.exe).
  2. Open putty.exe
  3. If a security warning is being displayed click on [Run]
  4. Enter underneath the label “Host Name or IP address”: 192.168.8.1 (or a different one if you hav e changed it)
  5. Make sure that the port is: 22 (or different if you have changed it)
  6. Click on [Open]
A black window window will appear.
  1. If a popup appears containing the title “PuTTY Security Alert” click on Yes, else go to step 8.
  2. When on the top left corner “Login as:” is being displayed enter “root” and press [Enter] afterwards.
  3. Next enter your password and press [Enter] afterwards.
Step 8 and 9 may repeat itself till the correct username and password are being entered,
  1. Now you are able to type and press [Enter] afterwards: <span style=“line-height: 1.5;”>opkg --force-downgrade aria2c</span>
