Need Help
Has anyone here successfully set up AriaNg and Aria2? I followed instructions with the help of ChatGPT, and everything installed properly — even the AriaNg web interface loads fine.
However, when I try to download something, it starts connecting, then gets disconnected, and the loop keeps happening. It initially connects, but as soon as I add a download task, it goes into this connecting-then-disconnected loop.
Also, I have a 4TB external hard drive with two partitions — one is exFAT and the other is NTFS. I want all the downloads to go to either of them (doesn't matter which one), but I’m not sure if that’s causing any issue. The Router Gl.inet Slate AX
Any ideas on what might be wrong? I'd really appreciate your help!
