AstroWarp in China?
Does anyone know if the new AstroWarp service works while the Slate 7 is in China, and the Flint 2 is back home in Chicago?
I searched "China", but it's talking about a lot of terms I'm unfamiliar with, and AstroWarp seems pretty simple, so I wonder if it has any luck.
I'm not talking about traditional NordVPN, ExpressVPN type things. Just using a travel router to use the IP from home in the U.S while traveling?
It seems like this should work totally fine in places like Thailand, the Philippines, Malaysia, Bali, etc. But China is unique.
Thanks.
AstroWarp is currently not supported for use within mainland China, and we do not provide server nodes in that region.
Since AstroWarp is based on the WireGuard protocol, its traffic patterns are easily identifiable when connecting to overseas nodes from mainland China, which may lead to it being blocked after prolonged use.
