AXt1800 router problems with Proton VPN OpenVPN tcp setup
I can’t setup VPN connection.
“Thu Nov 9 04:17:13 2023 daemon.warn ovpnclient[29993]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts\nThu Nov 9 04:17:13 2023 daemon.notice ovpnclient[29993]: TCP/UDP: Preserving recently used remote address: [AF_INET]45.14.71.5:7770\nThu Nov 9 04:17:13 2023 daemon.notice ovpnclient[29993]: Attempting to establish TCP connection with [AF_INET]45.14.71.5:7770 [nonblock]\nThu Nov 9 04:17:13 2023 daemon.notice ovpnclient[29993]: TCP connection established with [AF_INET]45.14.71.5:7770\nThu Nov 9 04:17:13 2023 daemon.notice ovpnclient[29993]: TCP_CLIENT link local: (not bound)\nThu Nov 9 04:17:13 2023 daemon.notice ovpnclient[29993]: TCP_CLIENT link remote: [AF_INET]45.14.71.5:7770\nThu Nov 9 04:17:13 2023 daemon.err ovpnclient[29993]: Connection reset, restarting [0]\nThu Nov 9 04:17:13 2023 daemon.notice ovpnclient[29993]: SIGHUP[soft,connection-reset] received, process restarting\nThu Nov 9 04:17:13 2023 daemon.notice ovpnclient[29993]: OpenVPN 2.5.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]\nThu Nov 9 04:17:13 2023 daemon.notice ovpnclient[29993]: library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10\nThu Nov 9 04:17:15 2023 daemon.warn ovpnclient[29993]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts\nThu Nov 9 04:17:15 2023 daemon.notice ovpnclient[29993]: TCP/UDP: Preserving recently used remote address: [AF_INET]45.14.71.5:8443\nThu Nov 9 04:17:15 2023 daemon.notice ovpnclient[29993]: Attempting to establish TCP connection with [AF_INET]45.14.71.5:8443 [nonblock]\nThu Nov 9 04:17:15 2023 daemon.notice ovpnclient[29993]: TCP connection established with [AF_INET]45.14.71.5:8443\nThu Nov 9 04:17:15 2023 daemon.notice ovpnclient[29993]: TCP_CLIENT link local: (not bound)\nThu Nov 9 04:17:15 2023 daemon.notice ovpnclient[29993]: TCP_CLIENT link remote: [AF_INET]45.14.71.5:8443\nThu Nov 9 04:17:15 2023 daemon.err ovpnclient[29993]: Connection reset, restarting [0]\nThu Nov 9 04:17:15 2023 daemon.notice ovpnclient[29993]: SIGHUP[soft,connection-reset] received, process restarting\nThu Nov 9 04:17:15 2023 daemon.notice ovpnclient[29993]: OpenVPN 2.5.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]\nThu Nov 9 04:17:15 2023 daemon.notice ovpnclient[29993]: library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10\n”
How did you set up the connection?
Got the openvpn files from the proton website and uploaded them in the openvpn client tab. Does this answer your question?
Yup. Does the config work when you use it from another device like your PC?
Haven’t tried, will do
This is the content of the file
client
dev tun
proto tcp
remote 103.125.235.18 7770
remote 103.125.235.18 443
remote 103.125.235.18 8443
remote-random
resolv-retry infinite
nobind
cipher AES-256-GCM
setenv CLIENT_CERT 0
tun-mtu 1500
mssfix 0
persist-key
persist-tun
reneg-sec 0
remote-cert-tls server
auth-user-pass
above logs…
Just a guess because I am just on my phone right now: Maybe it’s not possible to use OpenVPN with user password? Is there even a place where you can enter it on the router?
When I upload the file, router asks me for username and password, I set protonvpn username password
So you might test if they are correct.
