Hello, I’m have two routers b-1300, with configuration s2s (wg0) via goodcloud.xyz and wireguard server (wg1) for mobile and others clients on router A, try to open port via web interface to local network machine (my server) but port is closed. Bug from new firmware 3.105? How to fix?
Should you just use the route settings from GoodCloud S2S settings?
default routes as s2s is setup
Same, I opened ports manually but my Synology NAS still complains
