Symptoms:
With GL-iNet interface luci-app-adblock install fails with error 255
With LEDE interface luci-app-adblock install fails with error 255
With SSH opkg install luci-app-adblock fails with error “wget not found”
With SSH opkg install luci-app-adblock --force-depends succeeds despite “wget not found”
Installing uclient-fetch or wget-nossl with SSH still gives “wget not found” in system log when Adblock is started using luci
Can you try using ssh and shell?
opkg update
opkg install xxxx
There’s no error 255 but since wget (with ssl) is not in the repository, Adblock cannot function.
What if do using —force
or install wget together
I tried with --force-depends, then installed wget-nossl (wget is not available). I gives “wget not found” in the system log and Adblock cannot start.
