Noticed that 3.012 Beta does not allow hairpinning to a NAT’ed device…
Steps:
From clean flash…
Set a DHCP reservation for a wired LAN client, ensure that LAN client continues to use the DHCP address
1a) in this example, 192.168.8.180 -
LAN client has an OpenSSH server, so go to Firewall, set port forward to LAN Host IP, TCP, Port 22 on Internal and External Ports
Attempt to SSH to LAN client from WAN side - should pass successfully
3a) Attempt to SSH to LAN host from LAN side using LAN host IP - should pass -
Attempt to SSH from LAN side to WAN IP:port - should pass
In Step 4 - the current B1300 build fails.
Testing with AR300M 3.013 Beta, this passes… but that’s different upstream.
Artifact of the QSDK build on B1300?
