Collected errors:
* satisfy_dependencies_for: Cannot satisfy the following dependencies for athdiag:
* qca-wifi *
* satisfy_dependencies_for: Cannot satisfy the following dependencies for kmod-qca-wifi-unified-profile:
* iproute2 *
* opkg_download: Failed to download http://download.gl-inet.com/releases/packages-3.x/ipq40xx/sync_3.105/gl-mqtt_3.1.19-1_ipq806x.ipk, wget returned 8.
* opkg_install_pkg: Failed to download gl-mqtt. Perhaps you need to run 'opkg update'?
* opkg_install_cmd: Cannot install package gl-cloud-ui.
make[2]: *** [Makefile:143: package_install] Error 255
make[2]: Leaving directory '/home/gaosan/router/imagebuilder/imagebuilder/3.1/openwrt-imagebuilder-ipq806x-QSDK_Premium_3.1'
make[1]: *** [Makefile:113: _call_image] Error 2
make[1]: Leaving directory '/home/gaosan/router/imagebuilder/imagebuilder/3.1/openwrt-imagebuilder-ipq806x-QSDK_Premium_3.1'
make: *** [Makefile:199:image] 错误 2
Failed to build QSDK_Premium...
gl-cloud-ui和gl-mqtt 下载失败,请检查看看是不是网络问题
确定这个 http://download.gl-inet.com/releases/packages-3.x/ipq40xx/sync_3.105/gl-mqtt_3.1.19-1_ipq806x.ipk
这个地址是没有的了,不是网络问题
因为你的Packages里面用的就是3.1.19版本的http://download.gl-inet.com.s3.amazonaws.com/releases/packages-3.x/ipq40xx/sync_3.105/Packages
刚刚修复了,现在应该可以了,麻烦试一试一试
好了,好了,非常感谢大佬的支持~~~~~~~~
