Hello to all,
I have a speed problem with my b1300 in wifi (and LAN).
I cant obtain more then 10mb … in my vdsl 100mb. Connected on expressvpn permanently (20mb with VPN off)
image setting: 2018 07 01 15 21 15 GL i Net — ImgBB
Hello to all,
Are you working on 2.4G? Can you try 5G wifi?
Regardless openvpn, wifi should not be the bottleneck.
B1300 should achieve up to 25Mbps openvpn.
2,4 or 5 is the same… 10-12 with vpn on.
With OpenVPN on, the bottleneck is cpu computation power.
Can you post your ovpn settings so that we can check the cyphers
