B3000 no gui cant change IP
Updated the firmware to the latest beta and am stuck in luci. Also I cant change the IP so it doesn't conflict with my Flint 2. I am planing to use this router for VPNS and to replace the Opal I am using which works just fine but is slow,
  1. Only the luci works, did you upgrade the router firmware from the old one with "keep settings"?
  2. It is possible that the configuration conflicts will cause the GL GUI process to fail to start.
    Please try to reset the firmware, long press the reset button 8s after the B3000 has booted up.
Somehow it resolved itself and is now working
