Back up config over SSL
In Luci, it is possible to create a TAR image of the router configuration.
Is there a way to do that over the SSL connection? Iā€™m hoping there is a way to create the image as a local file on the router, then retrieve that file with WinSCP or the like.
Thanks.
Don
You could develop your own TAR shell script. You can get the current backup file list via LuCI ā†’ System ā†’ Backup / Flash Firmware ā†’ Configuration ā†’ Open List.
I do not work for and I am not directly associated with GL.iNettar
