Be-9300 tx retry’s with streaming issues over the iot network
Be9300 retry’s and streaming issues over the Iot network.
Mesh network, moved tv from mesh node to main node because of signal strength. Had chat GPT help with collection of statistics.
Over 6 min.
Counter Start End Increase
RX errors 976 1,262 +286
TX errors 7,718 15,084 +7,366
RX dropped 0 0 0
TX dropped 0 0 0
Measurement Reading Interpretation
Signal -42 dBm Excellent
Signal average -42 dBm Very stable
TX bitrate 1332.8 Mbps High
RX bitrate 100 Mbps Lower
TX retries 88,244 Very high cumulative count
TX failed 0 No final failures reported
RX drop misc 0 No miscellaneous RX drops
The TV is accumulating retries very rapidly
Over approximately 6 minutes and 15 seconds:
Starting retries: 95,499
Ending retries: 119,733
Additional retries: 24,234
Average: approximately 65 retries per second
2. Signal strength is not the problem
Throughout the test:
Signal stayed between -40 and -43 dBm.
That's an exceptionally strong signal.
tx failed remained zero.
Counter First Second Increase
TX packets 772,022 783,117 11,095
TX retries 140,700 143,169 2,469
TX failed 0 0 0
The retry increase is about 22.3% of the additional TX packet count.
If those readings were approximately 60 seconds apart, that's 2,469 retries in one minute.
Hi, thanks for sharing the test results. Could you help confirm the following?
  1. Which device is your Flint 3 meshed with, and what firmware versions are both nodes running?
    Did the streaming issue start after moving the TV to the main node, and was playback working fine on the sub-node?
  2. Which band is the TV using on the IoT network, and does the issue also occur on the main Wi-Fi network using the same node, band, and streaming app?
  3. When it happens again, could you please note the time, export the system log from the node the TV is connected to, and send it to us via private message?
These details will help us better understand your setup and narrow down the cause. Thank you for your understanding and support.
