Just came here to say that I am facing the very same issue with just 2 basic apps: adguard home + tailscale, low traffic, in just about 10/15 minutes the load is high enough to make the router unusable.
OK the ram crisis, but what’s the sense of putting out in the market a portable router that cannot even satisfy the basic portability requirements ?
I think that beyl ax at this stage it’s a better choice, not sure tho.
Update: enabling zram seems to have substantially improved stability on my Beryl 7, running firmware 4.9.0.
I initially also added GOMEMLIMIT=100MiB and GOGC=40 to AdGuard’s startup environment. I have since removed those overrides and restarted AdGuard, leaving zram enabled.
AdGuard Home and the bundled Tailscale have now run together for over three hours without those overrides. Previously, my router became unusable within roughly 10–15 minutes.
Latest measurements:
Load average:
0.21 / 0.29 / 0.34 -
Available RAM: approximately 57 MiB
Zram: approximately 90 MiB stored using 24 MiB of physical RAM
Installation through the UI
Go to Applications → Plug-ins, refresh the package list, search for zram, and install zram-swap. It depends on kmod-zram, so installing the kernel module alone is insufficient. GL.iNet documents package installation here (https://docs.gl-inet.com/router/en/4/interface_guide/plugins/).
For the explicit configuration I used, run the UCI commands below over SSH.
Installation and configuration through SSH
For a fresh setup, using the router’s configured package repositories:
opkg update
opkg install zram-swap
uci set system.@system[0].zram_size_mb='240'
uci set system.@system[0].zram_comp_algo='lzo'
uci set system.@system[0].zram_priority='100'
uci commit system
modprobe zram
/etc/init.d/zram enable
/etc/init.d/zram start
If zram is already active, these configuration changes do not resize it immediately. Avoid restarting active swap under memory pressure.
Verify activation and usage:
cat /proc/swaps
cat /sys/block/zram0/comp_algorithm
cat /sys/block/zram0/mm_stat
/proc/swaps should show /dev/zram0. The first three mm_stat values are uncompressed data size, compressed data size, and physical RAM used, in bytes.
This remains a promising workaround, not a confirmed fix or a controlled benchmark. I’m continuing to monitor it and will report any recurrence.
I've also affected by this and quite disheartened as adguardhome is a requirement for my case.
This is still in return period for me, as the official communication here is that the RAM might be insufficient I wonder if the best case for me would be to return it.
There is nextdns.io. It is similar to AdGuard Home and runs in the cloud. You cannot add custom lists, but most of the popular ones are there. It runs much faster than AdGuard Home due to it being on servers and not an ARM device. If you desire the privacy perks of AdGuard Home or you must use it for whatever other reason, I think the Beryl 7 is a no go.
if nextdns is not a option, another way to look at this is, if you are remote and you use vpn and your remote endpoint is a stronger router or device with Adguardhome.
Then you could point the dns to the tunnel gateway, you could also cascade vpn from the home router.
This will only work if your Beryl 7 is used to remote into your home network, if your Beryl 7 is used as main router or something then it won't work.
At my own setup I use it like this, but that works not for everyone.
Configuring zram also seems to have improved the situation for me. I wonder why it's not set as default with these low memory devices.
Does zram involve a tradeoff? I wonder if it raises CPU use. For now, like the OP, I have switched back to a Beryl AX, which seems to perform better. I am not implying Beryl 7 is a poor product, but it should have shipped with more than 500 MB of RAM.
How much difference is there in free ram between the Beryl AX and 7 models?
Much less with the Beryl 7, it was down to like 15MB, whereas the Beryl AX had like 145MB as I remember.
