Beryl AX (GL-MT3000) OpenVPN Failed due to lack of client support
OpenVPN log:
ovpnclient[13650]: AUTH: Received control message: AUTH_FAILED,SSO Auth Failed due to lack of client support
Google says:
This means to say “You are trying to connect with an account that is configured to use Single-Sign On Authentication. But your OpenVPN client is lacking the ability to do Single-Sign On Authentication”.
You have 2 options:
  • Use an OpenVPN client that support SSO auth, like OpenVPN Connect v3
  • Or configure the authentication method on OpenVPN Cloud so that it doesn’t use the SSO authentication method
Looking for a more complete solution for an update to the OpenVPN client on the GL-MT3000.
What is the OpenVPN server or OperVPN provider you are trying to connect to?
