Hi! I have a Beryl AX, firmware 4.2.3. Its set up as a repeater to my home ISP provided router via the 2.4G SSID. I have a work laptop with a LAN connection to the Beryl. I have a Wireguard PIA client setup, with a kill switch activated. Other devices connected to the ISP router does not drop connection but randomly, the wired connection to the Beryl drops out. Don’t think its the physical ethernet connection because the laptop still registers the ethernet connection but it says “No internet access”. Sometimes, I will still have internet access despite “No internet access” appearing and sometimes I actually dont have internet access
Connecting to the Beryl via Wifi is not feasible because of remote work. I unplug the LAN connection and replug it and it fixes it. Any fixes and suggestions to remedy the issue? I’d post the logs but need some guidance on how to anonymize the domains, IP and MAC addresses.
Thanks for any suggestions!
How long cable do you use to connect your computer to Beryl AX?
Is there a switch in between?
its a 10ft cable and no switch
Is wireguard client running on Beryl? Can you confirm whether wireguard is disconnected or the connection between the computer and Beryl is disconnected?
Can you ping Beryl when the network is down?
ping 192.168.8.1
Yes, the WireGuard client is running on the Beryl. I didn’t check whether wireguard is running at the point of disconnection. I haven’t tried pinging the Beryl but I am able to open the admin panel when its down. Next time it happens, I’ll take a look at the WireGuard status and ping the Beryl.
Here’s the system log for an instance that I lost connection for two devices connected to the router. I removed unique identifiers and replaced them with a “1” or “2” suffix. I unplug/replugged right after the 15:00:50 time stamp and internet was restored.
Thu Aug 17 14:43:44 2023 kern.notice kernel: [56432.654475] 7981@C15L3,PeerGroupMsg1Action() 7061: ===>Receive group msg 1
Thu Aug 17 15:00:18 2023 kern.info kernel: [57425.979285] mtk_soc_eth 15100000.ethernet eth1: Link is Down
Thu Aug 17 15:00:18 2023 kern.info kernel: [57425.985068] br-lan: port 1(eth1) entered disabled state
Thu Aug 17 15:00:18 2023 daemon.notice netifd: Network device ‘eth1’ link is down
Thu Aug 17 15:00:30 2023 kern.info kernel: [57438.264265] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
Thu Aug 17 15:00:30 2023 kern.info kernel: [57438.272736] br-lan: port 1(eth1) entered blocking state
Thu Aug 17 15:00:30 2023 kern.info kernel: [57438.277966] br-lan: port 1(eth1) entered forwarding state
Thu Aug 17 15:00:30 2023 daemon.notice netifd: Network device ‘eth1’ link is up
Thu Aug 17 15:00:35 2023 kern.info kernel: [57443.382919] mtk_soc_eth 15100000.ethernet eth1: Link is Down
Thu Aug 17 15:00:35 2023 kern.info kernel: [57443.388697] br-lan: port 1(eth1) entered disabled state
Thu Aug 17 15:00:35 2023 daemon.notice netifd: Network device ‘eth1’ link is down
Thu Aug 17 15:00:37 2023 kern.info kernel: [57445.430529] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
Thu Aug 17 15:00:37 2023 kern.info kernel: [57445.439148] br-lan: port 1(eth1) entered blocking state
Thu Aug 17 15:00:37 2023 kern.info kernel: [57445.444425] br-lan: port 1(eth1) entered forwarding state
Thu Aug 17 15:00:37 2023 daemon.notice netifd: Network device ‘eth1’ link is up
Thu Aug 17 15:00:38 2023 daemon.info dnsmasq-dhcp[2737]: DHCPREQUEST(br-lan) IPADDRESS1 MACADDRESS1
Thu Aug 17 15:00:38 2023 daemon.warn dnsmasq-dhcp[2737]: Ignoring domain WORKDOMAIN.com for DHCP host name LAPTOP1
Thu Aug 17 15:00:38 2023 daemon.info dnsmasq-dhcp[2737]: DHCPACK(br-lan) IPADDRESS1 MACADDRESS1 LAPTOP1
Thu Aug 17 15:00:42 2023 kern.notice kernel: [57450.223022] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(0), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023] MACADDRESS2
Thu Aug 17 15:00:42 2023 kern.debug kernel: [57450.235965] entrytb_aid_aquire(): found non-occupied aid:5, allocated from:4
Thu Aug 17 15:00:42 2023 kern.warn kernel: [57450.243054] 7981@C13L2,MacTableInsertEntry() 1537: New Sta: MACADDRESS2
Thu Aug 17 15:00:42 2023 kern.notice kernel: [57450.252597] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647: Recv Assoc from STA – MACADDRESS2
Thu Aug 17 15:00:42 2023 kern.notice kernel: [57450.261892] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)…
Thu Aug 17 15:00:42 2023 kern.notice kernel: [57450.270984] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Thu Aug 17 15:00:42 2023 kern.notice kernel: [57450.277044] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Thu Aug 17 15:00:42 2023 kern.notice kernel: [57450.397789] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Thu Aug 17 15:00:42 2023 kern.notice kernel: [57450.404513] 7981@C15L3,PeerPairMsg2Action() 6199: ===>Receive msg 2
Thu Aug 17 15:00:42 2023 kern.notice kernel: [57450.411699] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Thu Aug 17 15:00:42 2023 kern.notice kernel: [57450.418973] 7981@C15L3,PeerPairMsg4Action() 6629: ===>Receive msg 4
Thu Aug 17 15:00:42 2023 kern.warn kernel: [57450.431622] 7981@C15L2,PeerPairMsg4Action() 6991: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=2 from MACADDRESS2
Thu Aug 17 15:00:42 2023 daemon.info dnsmasq-dhcp[2737]: DHCPREQUEST(br-lan) IPADDRESS2 MACADDRESS2
Thu Aug 17 15:00:42 2023 daemon.info dnsmasq-dhcp[2737]: DHCPACK(br-lan) IPADDRESS2 MACADDRESS2 LAPTOP2
Thu Aug 17 15:00:44 2023 daemon.info dnsmasq-dhcp[2737]: DHCPREQUEST(br-lan) IPADDRESS2 MACADDRESS2
Thu Aug 17 15:00:44 2023 daemon.info dnsmasq-dhcp[2737]: DHCPACK(br-lan) IPADDRESS2 MACADDRESS2 LAPTOP2
Thu Aug 17 15:00:46 2023 daemon.info dnsmasq-dhcp[2737]: DHCPREQUEST(br-lan) IPADDRESS2 MACADDRESS2
Thu Aug 17 15:00:46 2023 daemon.info dnsmasq-dhcp[2737]: DHCPACK(br-lan) IPADDRESS2 MACADDRESS2 LAPTOP2
Thu Aug 17 15:00:50 2023 daemon.info dnsmasq-dhcp[2737]: DHCPREQUEST(br-lan) IPADDRESS1 MACADDRESS1
Thu Aug 17 15:00:50 2023 daemon.warn dnsmasq-dhcp[2737]: Ignoring domain WORKDOMAIN.com for DHCP host name LAPTOP1
Thu Aug 17 15:00:50 2023 daemon.info dnsmasq-dhcp[2737]: DHCPACK(br-lan) IPADDRESS1 MACADDRESS1 LAPTOP1
Thu Aug 17 15:43:44 2023 kern.notice kernel: [60031.900021] 7981@C15L3,PeerGroupMsg1Action() 7061: ===>Receive group msg 1
Just went out again but connected to Beryl 2.4G on different device. Successfully pinged 192.168.8.1 with 4 sent and 4 received with 0% loss. WireGuard client is trying to reconnect with yellow circle. No internet connection thru Beryl but I have internet connection through ISP router. May or may not be a related issue??? I attached the log. Tried to reboot Beryl and still doesn’t connect.
Fri Aug 18 00:09:27 2023 kern.warn kernel: [90367.041952] 7981@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=0
Fri Aug 18 00:09:27 2023 kern.notice kernel: [90367.048123] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=0
Fri Aug 18 00:09:27 2023 kern.warn kernel: [90367.055275] 7981@C13L2,MacTableDeleteEntry() 1793: Del Sta:a0:29:42:a5:c9:ae
Fri Aug 18 00:09:27 2023 kern.notice kernel: [90367.062469] 7981@C08L3,ap_peer_deauth_action() 429: AUTH - receive DE-AUTH(seq-71) from a0:29:42:a5:c9:ae, reason=1
Fri Aug 18 00:09:55 2023 daemon.notice netifd: Interface 'wgclient' has lost the connection
Fri Aug 18 00:09:55 2023 user.notice mwan3[28931]: Execute ifdown event on interface wgclient (unknown)
Fri Aug 18 00:09:55 2023 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Fri Aug 18 00:09:58 2023 daemon.notice netifd: Network device 'wgclient' link is down
Fri Aug 18 00:09:58 2023 daemon.notice netifd: wgclient (29388): sh: 1: unknown operand
Fri Aug 18 00:09:58 2023 daemon.info dnsmasq[2737]: exiting on receipt of SIGTERM
Fri Aug 18 00:09:58 2023 daemon.notice netifd: Interface 'wgclient' is now down
Fri Aug 18 00:09:58 2023 daemon.notice netifd: Interface 'wgclient' is setting up now
Fri Aug 18 00:09:58 2023 daemon.info dnsmasq[29562]: Connected to system UBus
Fri Aug 18 00:09:58 2023 daemon.info dnsmasq[29562]: started, version 2.85 cachesize 150
Fri Aug 18 00:09:58 2023 daemon.info dnsmasq[29562]: DNS service limited to local subnets
Fri Aug 18 00:09:58 2023 daemon.info dnsmasq[29562]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Fri Aug 18 00:09:58 2023 daemon.info dnsmasq[29562]: UBus support enabled: connected to system bus
Fri Aug 18 00:09:58 2023 daemon.info dnsmasq-dhcp[29562]: DHCP, IP range 192.168.8.100 -- 192.168.8.249, lease time 12h
Fri Aug 18 00:09:58 2023 daemon.info dnsmasq[29562]: using only locally-known addresses for domain test
Fri Aug 18 00:09:58 2023 daemon.info dnsmasq[29562]: using only locally-known addresses for domain onion
Fri Aug 18 00:09:58 2023 daemon.info dnsmasq[29562]: using only locally-known addresses for domain localhost
Fri Aug 18 00:09:58 2023 daemon.info dnsmasq[29562]: using only locally-known addresses for domain invalid
Fri Aug 18 00:09:58 2023 daemon.info dnsmasq[29562]: using only locally-known addresses for domain bind
Fri Aug 18 00:09:58 2023 daemon.info dnsmasq[29562]: using nameserver 127.0.0.1#3053
Fri Aug 18 00:09:58 2023 daemon.info dnsmasq[29562]: using only locally-known addresses for domain lan
Fri Aug 18 00:09:58 2023 daemon.info dnsmasq[29562]: read /etc/hosts - 4 addresses
Fri Aug 18 00:09:58 2023 daemon.info dnsmasq[29562]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Fri Aug 18 00:09:58 2023 daemon.info dnsmasq-dhcp[29562]: read /etc/ethers - 0 addresses
Fri Aug 18 00:09:58 2023 user.warn : skip line without '=' Default
Fri Aug 18 00:09:59 2023 user.warn : skip line without '=' Default
Fri Aug 18 00:09:59 2023 user.notice mwan3[29566]: Execute ifdown event on interface wgclient (unknown)
Fri Aug 18 00:09:59 2023 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Fri Aug 18 00:11:41 2023 kern.notice kernel: [90501.296299] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(0), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]a0:29:42:a5:c9:ae
Fri Aug 18 00:11:41 2023 kern.debug kernel: [90501.309224] entrytb_aid_aquire(): found non-occupied aid:6, allocated from:4
Fri Aug 18 00:11:41 2023 kern.warn kernel: [90501.316286] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:a0:29:42:a5:c9:ae
Fri Aug 18 00:11:41 2023 kern.notice kernel: [90501.333487] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647: Recv Assoc from STA - a0:29:42:a5:c9:ae
Fri Aug 18 00:11:41 2023 kern.notice kernel: [90501.342755] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Fri Aug 18 00:11:41 2023 kern.notice kernel: [90501.351845] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Fri Aug 18 00:11:41 2023 kern.notice kernel: [90501.357868] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Fri Aug 18 00:11:41 2023 kern.notice kernel: [90501.481057] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Fri Aug 18 00:11:41 2023 kern.notice kernel: [90501.487680] 7981@C15L3,PeerPairMsg2Action() 6199: ===>Receive msg 2
Fri Aug 18 00:11:41 2023 kern.notice kernel: [90501.494409] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Fri Aug 18 00:11:41 2023 kern.notice kernel: [90501.510496] 7981@C15L3,PeerPairMsg4Action() 6629: ===>Receive msg 4
Fri Aug 18 00:11:41 2023 kern.warn kernel: [90501.522038] 7981@C15L2,PeerPairMsg4Action() 6991: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=3 from a0:29:42:a5:c9:ae
Fri Aug 18 00:11:41 2023 daemon.info dnsmasq-dhcp[29562]: DHCPREQUEST(br-lan) 192.168.8.139 a0:29:42:a5:c9:ae
Fri Aug 18 00:11:41 2023 daemon.info dnsmasq-dhcp[29562]: DHCPACK(br-lan) 192.168.8.139 a0:29:42:a5:c9:ae DESKTOP-6UMBRFJ
Fri Aug 18 00:11:44 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-GIVEUP SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Fri Aug 18 00:11:48 2023 daemon.notice netifd: wgclient (2778): RTNETLINK answers: No such process
Fri Aug 18 00:11:48 2023 daemon.notice netifd: Interface 'wgclient' is now down
Fri Aug 18 00:11:48 2023 daemon.notice netifd: Interface 'wgclient' is setting up now
Fri Aug 18 00:11:48 2023 user.warn : skip line without '=' Default
Fri Aug 18 00:11:48 2023 user.notice mwan3[2810]: Execute ifdown event on interface wgclient (unknown)
Fri Aug 18 00:11:48 2023 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Fri Aug 18 00:11:57 2023 kern.warn kernel: [90517.616887] 7981@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=0
Fri Aug 18 00:11:57 2023 kern.notice kernel: [90517.623069] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=0
Fri Aug 18 00:11:57 2023 kern.warn kernel: [90517.630329] 7981@C13L2,MacTableDeleteEntry() 1793: Del Sta:a0:29:42:a5:c9:ae
Fri Aug 18 00:11:57 2023 kern.notice kernel: [90517.637528] 7981@C08L3,ap_peer_deauth_action() 429: AUTH - receive DE-AUTH(seq-85) from a0:29:42:a5:c9:ae, reason=1
Fri Aug 18 00:11:57 2023 kern.notice kernel: [90517.676058] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(0), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]a0:29:42:a5:c9:ae
Fri Aug 18 00:11:57 2023 kern.debug kernel: [90517.688968] entrytb_aid_aquire(): found non-occupied aid:6, allocated from:4
Fri Aug 18 00:11:57 2023 kern.warn kernel: [90517.696027] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:a0:29:42:a5:c9:ae
Fri Aug 18 00:11:58 2023 kern.notice kernel: [90517.706777] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647: Recv Assoc from STA - a0:29:42:a5:c9:ae
Fri Aug 18 00:11:58 2023 kern.notice kernel: [90517.716050] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ReASSOC Send ReASSOC response (Status=0)...
Fri Aug 18 00:11:58 2023 kern.notice kernel: [90517.725490] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Fri Aug 18 00:11:58 2023 kern.notice kernel: [90517.731512] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Fri Aug 18 00:11:58 2023 kern.notice kernel: [90517.852960] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Fri Aug 18 00:11:58 2023 kern.notice kernel: [90517.859582] 7981@C15L3,PeerPairMsg2Action() 6199: ===>Receive msg 2
Fri Aug 18 00:11:58 2023 kern.notice kernel: [90517.866304] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Fri Aug 18 00:11:58 2023 kern.notice kernel: [90517.872967] 7981@C15L3,PeerPairMsg4Action() 6629: ===>Receive msg 4
Fri Aug 18 00:11:58 2023 kern.warn kernel: [90517.884497] 7981@C15L2,PeerPairMsg4Action() 6991: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=3 from a0:29:42:a5:c9:ae
Fri Aug 18 00:11:58 2023 daemon.info dnsmasq-dhcp[29562]: DHCPREQUEST(br-lan) 192.168.8.139 a0:29:42:a5:c9:ae
Fri Aug 18 00:11:58 2023 daemon.info dnsmasq-dhcp[29562]: DHCPACK(br-lan) 192.168.8.139 a0:29:42:a5:c9:ae DESKTOP-6UMBRFJ
Fri Aug 18 00:12:14 2023 kern.warn kernel: [90533.750443] 7981@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=0
Fri Aug 18 00:12:14 2023 kern.notice kernel: [90533.757783] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=0
Fri Aug 18 00:12:14 2023 kern.warn kernel: [90533.764907] 7981@C13L2,MacTableDeleteEntry() 1793: Del Sta:a0:29:42:a5:c9:ae
Fri Aug 18 00:12:14 2023 kern.notice kernel: [90533.772107] 7981@C08L3,ap_peer_deauth_action() 429: AUTH - receive DE-AUTH(seq-92) from a0:29:42:a5:c9:ae, reason=1
Fri Aug 18 00:13:14 2023 kern.notice kernel: [90594.173736] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(0), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]a0:29:42:a5:c9:ae
Fri Aug 18 00:13:14 2023 kern.debug kernel: [90594.186645] entrytb_aid_aquire(): found non-occupied aid:6, allocated from:4
Fri Aug 18 00:13:14 2023 kern.warn kernel: [90594.193704] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:a0:29:42:a5:c9:ae
Fri Aug 18 00:13:14 2023 kern.notice kernel: [90594.206937] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647: Recv Assoc from STA - a0:29:42:a5:c9:ae
Fri Aug 18 00:13:14 2023 kern.notice kernel: [90594.216207] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Fri Aug 18 00:13:14 2023 kern.notice kernel: [90594.225303] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Fri Aug 18 00:13:14 2023 kern.notice kernel: [90594.231327] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Fri Aug 18 00:13:14 2023 kern.notice kernel: [90594.353853] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Fri Aug 18 00:13:14 2023 kern.notice kernel: [90594.360476] 7981@C15L3,PeerPairMsg2Action() 6199: ===>Receive msg 2
Fri Aug 18 00:13:14 2023 kern.notice kernel: [90594.367200] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Fri Aug 18 00:13:14 2023 kern.notice kernel: [90594.373851] 7981@C15L3,PeerPairMsg4Action() 6629: ===>Receive msg 4
Fri Aug 18 00:13:14 2023 kern.warn kernel: [90594.385392] 7981@C15L2,PeerPairMsg4Action() 6991: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=3 from a0:29:42:a5:c9:ae
Fri Aug 18 00:13:14 2023 daemon.info dnsmasq-dhcp[29562]: DHCPREQUEST(br-lan) 192.168.8.139 a0:29:42:a5:c9:ae
Fri Aug 18 00:13:14 2023 daemon.info dnsmasq-dhcp[29562]: DHCPACK(br-lan) 192.168.8.139 a0:29:42:a5:c9:ae DESKTOP-6UMBRFJ
Fri Aug 18 00:13:33 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-GIVEUP SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Fri Aug 18 00:13:36 2023 daemon.notice netifd: wgclient (8342): RTNETLINK answers: No such process
Fri Aug 18 00:13:36 2023 daemon.notice netifd: Interface 'wgclient' is now down
Fri Aug 18 00:13:36 2023 daemon.notice netifd: Interface 'wgclient' is setting up now
Fri Aug 18 00:13:36 2023 user.warn : skip line without '=' Default
Fri Aug 18 00:13:37 2023 user.notice mwan3[8373]: Execute ifdown event on interface wgclient (unknown)
Fri Aug 18 00:13:37 2023 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Fri Aug 18 00:15:22 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-GIVEUP SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Fri Aug 18 00:15:25 2023 kern.warn kernel: [90725.088698] 7981@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=0
Fri Aug 18 00:15:25 2023 kern.notice kernel: [90725.094879] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=0
Fri Aug 18 00:15:25 2023 kern.warn kernel: [90725.101987] 7981@C13L2,MacTableDeleteEntry() 1793: Del Sta:a0:29:42:a5:c9:ae
Fri Aug 18 00:15:25 2023 kern.notice kernel: [90725.109186] 7981@C08L3,ap_peer_deauth_action() 429: AUTH - receive DE-AUTH(seq-13) from a0:29:42:a5:c9:ae, reason=1
Fri Aug 18 00:15:25 2023 daemon.notice netifd: wgclient (13881): RTNETLINK answers: No such process
Fri Aug 18 00:15:25 2023 daemon.notice netifd: Interface 'wgclient' is now down
Fri Aug 18 00:15:25 2023 daemon.notice netifd: Interface 'wgclient' is setting up now
Fri Aug 18 00:15:25 2023 user.warn : skip line without '=' Default
Fri Aug 18 00:15:26 2023 user.warn : skip line without '=' Default
Fri Aug 18 00:15:26 2023 user.notice mwan3[13912]: Execute ifdown event on interface wgclient (unknown)
Fri Aug 18 00:15:26 2023 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Fri Aug 18 00:15:47 2023 kern.notice kernel: [90747.175811] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(0), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]a0:29:42:a5:c9:ae
Fri Aug 18 00:15:47 2023 kern.debug kernel: [90747.188721] entrytb_aid_aquire(): found non-occupied aid:6, allocated from:4
Fri Aug 18 00:15:47 2023 kern.warn kernel: [90747.195780] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:a0:29:42:a5:c9:ae
Fri Aug 18 00:15:47 2023 kern.notice kernel: [90747.208074] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647: Recv Assoc from STA - a0:29:42:a5:c9:ae
Fri Aug 18 00:15:47 2023 kern.notice kernel: [90747.217342] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Fri Aug 18 00:15:47 2023 kern.notice kernel: [90747.226432] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Fri Aug 18 00:15:47 2023 kern.notice kernel: [90747.232452] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Fri Aug 18 00:15:47 2023 kern.notice kernel: [90747.355626] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Fri Aug 18 00:15:47 2023 kern.notice kernel: [90747.362248] 7981@C15L3,PeerPairMsg2Action() 6199: ===>Receive msg 2
Fri Aug 18 00:15:47 2023 kern.notice kernel: [90747.368975] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Fri Aug 18 00:15:47 2023 kern.notice kernel: [90747.375601] 7981@C15L3,PeerPairMsg4Action() 6629: ===>Receive msg 4
Fri Aug 18 00:15:47 2023 kern.warn kernel: [90747.387106] 7981@C15L2,PeerPairMsg4Action() 6991: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=3 from a0:29:42:a5:c9:ae
Fri Aug 18 00:15:47 2023 daemon.info dnsmasq-dhcp[29562]: DHCPREQUEST(br-lan) 192.168.8.139 a0:29:42:a5:c9:ae
Fri Aug 18 00:15:47 2023 daemon.info dnsmasq-dhcp[29562]: DHCPACK(br-lan) 192.168.8.139 a0:29:42:a5:c9:ae DESKTOP-6UMBRFJ
Fri Aug 18 00:17:11 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-GIVEUP SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Fri Aug 18 00:17:14 2023 daemon.notice netifd: wgclient (19440): RTNETLINK answers: No such process
Fri Aug 18 00:17:14 2023 daemon.notice netifd: Interface 'wgclient' is now down
Fri Aug 18 00:17:14 2023 daemon.notice netifd: Interface 'wgclient' is setting up now
Fri Aug 18 00:17:14 2023 user.warn : skip line without '=' Default
Fri Aug 18 00:17:14 2023 user.notice mwan3[19471]: Execute ifdown event on interface wgclient (unknown)
Fri Aug 18 00:17:15 2023 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Fri Aug 18 00:18:14 2023 daemon.info dnsmasq[29562]: exiting on receipt of SIGTERM
Fri Aug 18 00:18:14 2023 daemon.notice netifd: wgclient (22921): RTNETLINK answers: No such process
Fri Aug 18 00:18:14 2023 daemon.notice netifd: Interface 'wgclient' is now down
Fri Aug 18 00:18:14 2023 daemon.info dnsmasq[23117]: Connected to system UBus
Fri Aug 18 00:18:14 2023 daemon.info dnsmasq[23117]: started, version 2.85 cachesize 150
Fri Aug 18 00:18:14 2023 daemon.info dnsmasq[23117]: DNS service limited to local subnets
Fri Aug 18 00:18:14 2023 daemon.info dnsmasq[23117]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Fri Aug 18 00:18:14 2023 daemon.info dnsmasq[23117]: UBus support enabled: connected to system bus
Fri Aug 18 00:18:14 2023 daemon.info dnsmasq-dhcp[23117]: DHCP, IP range 192.168.8.100 -- 192.168.8.249, lease time 12h
Fri Aug 18 00:18:14 2023 daemon.info dnsmasq[23117]: using only locally-known addresses for domain test
Fri Aug 18 00:18:14 2023 daemon.info dnsmasq[23117]: using only locally-known addresses for domain onion
Fri Aug 18 00:18:14 2023 daemon.info dnsmasq[23117]: using only locally-known addresses for domain localhost
Fri Aug 18 00:18:14 2023 daemon.info dnsmasq[23117]: using only locally-known addresses for domain invalid
Fri Aug 18 00:18:14 2023 daemon.info dnsmasq[23117]: using only locally-known addresses for domain bind
Fri Aug 18 00:18:14 2023 daemon.info dnsmasq[23117]: using nameserver 127.0.0.1#3053
Fri Aug 18 00:18:14 2023 daemon.info dnsmasq[23117]: using only locally-known addresses for domain lan
Fri Aug 18 00:18:14 2023 daemon.info dnsmasq[23117]: read /etc/hosts - 4 addresses
Fri Aug 18 00:18:14 2023 daemon.info dnsmasq[23117]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Fri Aug 18 00:18:14 2023 daemon.info dnsmasq-dhcp[23117]: read /etc/ethers - 0 addresses
Fri Aug 18 00:18:14 2023 user.notice mwan3[23017]: Execute ifdown event on interface wgclient (unknown)
Fri Aug 18 00:18:14 2023 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Fri Aug 18 00:18:55 2023 kern.warn kernel: [90935.224976] 7981@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=0
Fri Aug 18 00:18:55 2023 kern.notice kernel: [90935.231167] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=0
Fri Aug 18 00:18:55 2023 kern.warn kernel: [90935.238319] 7981@C13L2,MacTableDeleteEntry() 1793: Del Sta:a0:29:42:a5:c9:ae
Fri Aug 18 00:18:55 2023 kern.notice kernel: [90935.245509] 7981@C08L3,ap_peer_deauth_action() 429: AUTH - receive DE-AUTH(seq-27) from a0:29:42:a5:c9:ae, reason=1
Fri Aug 18 00:19:05 2023 kern.notice kernel: [90945.251446] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(0), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]a0:29:42:a5:c9:ae
Fri Aug 18 00:19:05 2023 kern.debug kernel: [90945.264428] entrytb_aid_aquire(): found non-occupied aid:6, allocated from:4
Fri Aug 18 00:19:05 2023 kern.warn kernel: [90945.271538] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:a0:29:42:a5:c9:ae
Fri Aug 18 00:19:05 2023 kern.notice kernel: [90945.289753] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647: Recv Assoc from STA - a0:29:42:a5:c9:ae
Fri Aug 18 00:19:05 2023 kern.notice kernel: [90945.299092] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Fri Aug 18 00:19:05 2023 kern.notice kernel: [90945.308217] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Fri Aug 18 00:19:05 2023 kern.notice kernel: [90945.314434] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Fri Aug 18 00:19:05 2023 kern.notice kernel: [90945.434139] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Fri Aug 18 00:19:05 2023 kern.notice kernel: [90945.468505] 7981@C15L3,PeerPairMsg2Action() 6199: ===>Receive msg 2
Fri Aug 18 00:19:05 2023 kern.notice kernel: [90945.475233] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Fri Aug 18 00:19:05 2023 kern.notice kernel: [90945.483976] 7981@C15L3,PeerPairMsg4Action() 6629: ===>Receive msg 4
Fri Aug 18 00:19:05 2023 kern.warn kernel: [90945.495517] 7981@C15L2,PeerPairMsg4Action() 6991: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=3 from a0:29:42:a5:c9:ae
Fri Aug 18 00:19:05 2023 daemon.info dnsmasq-dhcp[23117]: DHCPREQUEST(br-lan) 192.168.8.139 a0:29:42:a5:c9:ae
Fri Aug 18 00:19:05 2023 daemon.info dnsmasq-dhcp[23117]: DHCPACK(br-lan) 192.168.8.139 a0:29:42:a5:c9:ae DESKTOP-6UMBRFJ
What power supply aka USB charger are you using?
