Beryl AX IP Configuration Failure
I can't seem to connect to the Beryl AX after making a change to Adguard Home. I added a device to the client settings. No issue before when I added devices to the client settings, but now I cannot even connect to the router to either get Internet or access the GUI. Help?
Can you ssh to it?
Arp -a show it's ip?
Does it normally provide DHCP?
Either continue to try to access or just restore.
I just retraced my steps during my tinkering and I believe it has to do with the "client settings" in Adguard Home. I can't pinpoint it as I don't have the time to test every single possible variable. I just removed everything and rebooted the Beryl AX. Everything seems to be working again.
This happened again. All my devices abruptly lost Internet earlier today. Before that, I switched my Pixel's WiFi network, going from the Beryl AX to my ISP-supplied modem/router to test something out, but then I couldn't switch back. The Pixel won't reconnect with the Beryl AX. There was a notification that the Pixel's private DNS cannot connect, which is weird, so I disabled it, and even then it can't reconnect to the Beryl. It was finally after rebooting the Beryl AX that all my devices got the Internet back and the Pixel was able to reconnect to the Beryl. I'm convinced this has to do with Adguard Home, client settings, and the upstream DNS server as I tried to implement @will.qiu's advice from another thread. Before that, I've had stability. Now I can't go through 24 hours without all my devices losing Internet and I have to reboot the router.
Below is a copy of the system log.
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome: Warning: Section @zone[3] (wgclient1) has no device, network, subnet or extra options
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome: Warning: Section @zone[4] (wgclient2) has no device, network, subnet or extra options
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:  * Clearing IPv4 filter table
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:  * Clearing IPv4 nat table
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:  * Clearing IPv4 mangle table
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:  * Clearing IPv4 raw table
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:  * Populating IPv4 filter table
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Rule 'guest_drop_leaked_dns'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Rule 'Allow-DHCP-Renew'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Rule 'Allow-IGMP'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Rule 'Allow-IPSec-ESP'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Rule 'Allow-ISAKMP'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Rule 'Allow-DHCP'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Rule 'Allow-DNS'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Rule 'lan_drop_leaked_dns'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Rule #12
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Rule #13
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Rule #14
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Rule #15
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Forward 'lan' -> 'wan'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Forward 'guest' -> 'wan'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Forward 'lan' -> 'wgclient1'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Forward 'guest' -> 'wgclient1'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Forward 'wan' -> 'wgclient1'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Forward 'lan' -> 'wgclient2'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Forward 'guest' -> 'wgclient2'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Forward 'wan' -> 'wgclient2'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Zone 'lan'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Zone 'wan'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Zone 'guest'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Zone 'wgclient1'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Zone 'wgclient2'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:  * Populating IPv4 nat table
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:  * Populating IPv4 mangle table
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:  * Populating IPv4 raw table
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:      - Using automatic conntrack helper attachment
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:  * Clearing IPv6 filter table
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:  * Clearing IPv6 nat table
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:  * Clearing IPv6 mangle table
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:  * Clearing IPv6 raw table
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:  * Populating IPv6 filter table
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Rule 'Allow-DHCPv6'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Rule 'Allow-MLD'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Rule 'Allow-ICMPv6-Input'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:    * Rule 'Allow-ICMPv6-Forward'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:  * Populating IPv6 nat table
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome: Warning: fw3_ipt_rule_append(): Can't find target 'prerouting_lan_rule'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome: Warning: fw3_ipt_rule_append(): Can't find target 'postrouting_lan_rule'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome: Warning: fw3_ipt_rule_append(): Can't find target 'prerouting_wan_rule'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome: Warning: fw3_ipt_rule_append(): Can't find target 'postrouting_wan_rule'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome: Warning: fw3_ipt_rule_append(): Can't find target 'prerouting_guest_rule'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome: Warning: fw3_ipt_rule_append(): Can't find target 'postrouting_guest_rule'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome: Warning: fw3_ipt_rule_append(): Can't find target 'prerouting_wgclient1_rule'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome: Warning: fw3_ipt_rule_append(): Can't find target 'postrouting_wgclient1_rule'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome: Warning: fw3_ipt_rule_append(): Can't find target 'prerouting_wgclient2_rule'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome: Warning: fw3_ipt_rule_append(): Can't find target 'postrouting_wgclient2_rule'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome: Warning: fw3_ipt_rule_append(): Can't find target 'prerouting_rule'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome: Warning: fw3_ipt_rule_append(): Can't find target 'postrouting_rule'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:  * Populating IPv6 mangle table
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:  * Populating IPv6 raw table
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:  * Set tcp_ecn to off
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:  * Set tcp_syncookies to on
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:  * Set tcp_window_scaling to on
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:  * Running script '/etc/firewall.nat6'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:  * Running script '/etc/firewall.dns_order'
Sat Aug 16 14:00:15 2025 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome: iptables: No chain/target/match by that name.
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:  * Running script '/usr/bin/gl_block.sh'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome:  * Running script '/etc/firewall-portal.user'
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome: Another app is currently holding the xtables lock. Perhaps you want to use the -w option?
Sat Aug 16 14:00:15 2025 daemon.notice procd: /etc/rc.d/S99adguardhome: /etc/edgerouter.fw: line 96: handle_dns: not found
Sat Aug 16 14:00:16 2025 daemon.notice procd: /etc/rc.d/S99disk_manage: start app = /usr/bin/disk_manage
Sat Aug 16 14:00:16 2025 daemon.info dnsmasq-dhcp[12017]: DHCPDISCOVER(br-lan) c4:98:5c:aa:b9:33
Sat Aug 16 14:00:16 2025 daemon.info dnsmasq-dhcp[12017]: DHCPOFFER(br-lan) 192.168.8.224 c4:98:5c:aa:b9:33
Sat Aug 16 14:00:16 2025 daemon.info dnsmasq-dhcp[12017]: DHCPREQUEST(br-lan) 192.168.8.224 c4:98:5c:aa:b9:33
Sat Aug 16 14:00:16 2025 daemon.info dnsmasq-dhcp[12017]: DHCPACK(br-lan) 192.168.8.224 c4:98:5c:aa:b9:33 65TCLRokuTV
Sat Aug 16 14:00:17 2025 daemon.notice procd: /etc/rc.d/S99gl_nas_sys_dl: start app = /usr/bin/gl_nas_sys
Sat Aug 16 14:00:17 2025 daemon.notice procd: /etc/rc.d/S99gl_nas_sys_dl: === nas enable
Sat Aug 16 14:00:17 2025 user.notice firewall: Reloading firewall due to ifup of loopback (lo)
Sat Aug 16 14:00:17 2025 daemon.notice procd: /etc/rc.d/S99gl_nas_sys_up: start app = /usr/bin/gl_nas_sys
Sat Aug 16 14:00:17 2025 daemon.notice procd: /etc/rc.d/S99gl_nas_sys_up: === nas enable
Sat Aug 16 14:00:18 2025 user.notice gl-switch: switch pressed
Sat Aug 16 14:00:18 2025 user.notice gl-switch: no config
Sat Aug 16 14:00:18 2025 daemon.notice procd: /etc/rc.d/S99usb3_disable: uci: Entry not found
Sat Aug 16 14:00:18 2025 daemon.notice procd: /etc/rc.d/S99webdav_ser: start app = /usr/bin/webdav_ser
Sat Aug 16 14:00:18 2025 daemon.info procd: - init complete -
Sat Aug 16 14:00:18 2025 user.notice AdGuardHome[13051]: 2025/08/16 14:00:18.677121 [info] AdGuard Home, version 0.107.56
Sat Aug 16 14:00:18 2025 user.notice AdGuardHome[13051]: 2025/08/16 14:00:18.716316 [info] tls: using default ciphers
Sat Aug 16 14:00:18 2025 user.notice AdGuardHome[13051]: 2025/08/16 14:00:18.751688 [info] Initializing auth module: /etc/AdGuardHome/data/sessions.db
Sat Aug 16 14:00:18 2025 user.notice AdGuardHome[13051]: 2025/08/16 14:00:18.755706 [info] auth: initialized.  users:0  sessions:0
Sat Aug 16 14:00:18 2025 user.notice AdGuardHome[13051]: 2025/08/16 14:00:18.755994 [info] webapi: initializing
Sat Aug 16 14:00:19 2025 daemon.info dnsmasq-dhcp[12017]: DHCPREQUEST(br-lan) 192.168.8.220 7c:0a:3f:10:b6:69
Sat Aug 16 14:00:19 2025 daemon.info dnsmasq-dhcp[12017]: DHCPACK(br-lan) 192.168.8.220 7c:0a:3f:10:b6:69 Samsung
Sat Aug 16 14:00:21 2025 user.notice AdGuardHome[13051]: 2025/08/16 14:00:21.491828 [info] dnsproxy: upstream mode is set mode=load_balance
Sat Aug 16 14:00:21 2025 user.notice AdGuardHome[13051]: 2025/08/16 14:00:21.491955 [info] dnsproxy: cache enabled size=4096
Sat Aug 16 14:00:21 2025 user.notice AdGuardHome[13051]: 2025/08/16 14:00:21.492011 [info] dnsproxy: max goroutines is set count=300
Sat Aug 16 14:00:21 2025 user.notice AdGuardHome[13051]: 2025/08/16 14:00:21.492193 [info] dnsproxy: ratelimit is enabled rps=20 ipv4_subnet_mask_len=24 ipv6_subnet_mask_len=56
Sat Aug 16 14:00:21 2025 user.notice AdGuardHome[13051]: 2025/08/16 14:00:21.492256 [info] dnsproxy: server will refuse requests of type any
Sat Aug 16 14:00:21 2025 user.notice AdGuardHome[13051]: 2025/08/16 14:00:21.492301 [info] dnsproxy: upstream mode is set mode=load_balance
Sat Aug 16 14:00:21 2025 user.notice AdGuardHome[13051]: 2025/08/16 14:00:21.492341 [info] dnsproxy: cache enabled size=4194304
Sat Aug 16 14:00:21 2025 user.notice AdGuardHome[13051]: 2025/08/16 14:00:21.492387 [info] dnsproxy: max goroutines is set count=300
Sat Aug 16 14:00:21 2025 user.notice AdGuardHome[13051]: 2025/08/16 14:00:21.508321 [info] addrproc: processing addresses
Sat Aug 16 14:00:21 2025 user.notice AdGuardHome[13051]: 2025/08/16 14:00:21.508393 [info] webapi: AdGuard Home is available at the following addresses:
Sat Aug 16 14:00:21 2025 user.notice AdGuardHome[13051]: 2025/08/16 14:00:21.517875 [info] go to http://127.0.0.1:3000
Sat Aug 16 14:00:21 2025 user.notice AdGuardHome[13051]: 2025/08/16 14:00:21.518059 [info] go to http://[::1]:3000
Sat Aug 16 14:00:21 2025 user.notice AdGuardHome[13051]: 2025/08/16 14:00:21.518155 [info] go to http://192.168.9.1:3000
Sat Aug 16 14:00:21 2025 user.notice AdGuardHome[13051]: 2025/08/16 14:00:21.518223 [info] go to http://192.168.8.1:3000
Sat Aug 16 14:00:25 2025 kern.warn kernel: [   49.250094] 7981@C01L2,RTMP_COM_IoctlHandle() 1517: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_INIT
Sat Aug 16 14:00:25 2025 kern.warn kernel: [   49.258331] 7981@C01L2,RTMP_COM_IoctlHandle() 1494:  -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_UP
Sat Aug 16 14:00:25 2025 kern.notice kernel: [   49.266381] WiFi@C01L3,wifi_sys_open() 856: wdev idx = 4
Sat Aug 16 14:00:25 2025 kern.notice kernel: [   49.272121] 7981@C18L3,BuildChannelList() 507:
Sat Aug 16 14:00:25 2025 kern.debug kernel: [   49.276814] wdev_attr_update(): wdevId4 = 92:83:c4:44:80:e8
Sat Aug 16 14:00:25 2025 kern.info kernel: [   49.282526] apcli0: update addr to: 92:83:c4:44:80:e8
Sat Aug 16 14:00:25 2025 kern.notice kernel: [   49.287788] 7981@C08L3,hw_ctrl_flow_v2_open() 13: wdev_idx=4
Sat Aug 16 14:00:25 2025 kern.info kernel: [   49.298895] mtk_ppe_dev_register_hook : ineterface apcli0 register (5)
Sat Aug 16 14:00:25 2025 kern.warn kernel: [   49.312289] 7981@C01L2,RTMP_COM_IoctlHandle() 1517: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_INIT
Sat Aug 16 14:00:25 2025 kern.warn kernel: [   49.320426] 7981@C01L2,RTMP_COM_IoctlHandle() 1494:  -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_UP
Sat Aug 16 14:00:25 2025 kern.notice kernel: [   49.328499] WiFi@C01L3,wifi_sys_open() 856: wdev idx = 5
Sat Aug 16 14:00:25 2025 kern.notice kernel: [   49.334138] 7981@C18L3,BuildChannelList() 507:
Sat Aug 16 14:00:25 2025 kern.debug kernel: [   49.341779] wdev_attr_update(): wdevId5 = 9e:83:c4:44:80:e8
Sat Aug 16 14:00:25 2025 kern.info kernel: [   49.347410] apclix0: update addr to: 9e:83:c4:44:80:e8
Sat Aug 16 14:00:25 2025 kern.notice kernel: [   49.353043] 7981@C08L3,hw_ctrl_flow_v2_open() 13: wdev_idx=5
Sat Aug 16 14:00:25 2025 kern.info kernel: [   49.369731] mtk_ppe_dev_register_hook : ineterface apclix0 register (6)
Sat Aug 16 14:00:25 2025 kern.debug kernel: [   49.379978] SetApCliEnableByWdev: I/F(apcli0) (enable = 0)
Sat Aug 16 14:00:25 2025 daemon.info gl-repeater[2575]: (gl-repeater.lua:192) load wifi config...
Sat Aug 16 14:00:25 2025 daemon.info gl-repeater[2575]: (gl-repeater.lua:214) found radio mt798111
Sat Aug 16 14:00:25 2025 daemon.info gl-repeater[2575]: (gl-repeater.lua:214) found radio mt798112
Sat Aug 16 14:00:25 2025 daemon.info gl-repeater[2575]: (gl-repeater.lua: 16) load repeater config...
Sat Aug 16 14:00:25 2025 kern.debug kernel: [   49.385736] SetApCliEnableByWdev: I/F(apcli1) (enable = 0)
Sat Aug 16 14:00:26 2025 daemon.info gl-repeater[2575]: (repeater.lua:1474) switch in 0 seconds...
Sat
Using dnscheck.tools, my Beryl AX with a VPN is now failing on what I believe to be some key points. How do I address this?
ECDSA P-256	ECDSA P-384	Ed25519
Valid signature	PASS	PASS	PASS
Invalid signature	FAIL	FAIL	FAIL
Expired signature	FAIL	FAIL	FAIL
Missing signature	FAIL	FAIL	FAIL
134ms EDNS DNSSEC IPv6
dns: 110
