Beryl AX Not Not Staying Connected
Hi there. I am attempting to connect via my new Beryl AX router on my Macbook Pro. When I first connect to the router everything works fine for a few minutes. I am able to set up my current network as a repeater. Then it goes out after roughly five minutes and pages just stay on loading and/or give me a time out error. http://192.168.8.1 also has unsecured warning when it goes bad. After that, I also have trouble getting back on my current network. I have to forget the current network and also have to renew the DCHP lease to get my ISP working again which takes a bit of time as well. I have been troubleshooting for a few days without any luck on a solution and could really use any suggestions or ideas on troubleshooting or a fix. Thanks so much.
Can you provide a log after this issue occurred?
@dengxinfa thanks so much for your reply. I am not totally sure everything I would need to post so this may not be enough to show but here are the last few readings from the logs. I am also checking on the firmware to see if that could be an issue:
Wed Aug 2 13:36:52 2023 daemon.notice netifd: Interface ‘wwan’ is now up
Wed Aug 2 13:36:52 2023 daemon.info dnsmasq[4081]: reading /tmp/resolv.conf.d/resolv.conf.auto
Wed Aug 2 13:36:52 2023 daemon.info dnsmasq[4081]: using only locally-known addresses for domain test
Wed Aug 2 13:36:52 2023 daemon.info dnsmasq[4081]: using only locally-known addresses for domain onion
Wed Aug 2 13:36:52 2023 daemon.info dnsmasq[4081]: using only locally-known addresses for domain localhost
Wed Aug 2 13:36:52 2023 daemon.info dnsmasq[4081]: using only locally-known addresses for domain invalid
Wed Aug 2 13:36:52 2023 daemon.info dnsmasq[4081]: using only locally-known addresses for domain bind
Wed Aug 2 13:36:52 2023 daemon.info dnsmasq[4081]: using only locally-known addresses for domain lan
Wed Aug 2 13:36:52 2023 daemon.info dnsmasq[4081]: using nameserver 192.168.1.1#53
Wed Aug 2 13:36:53 2023 user.notice mwan3[8530]: Execute ifup event on interface wwan (apclix0)
Wed Aug 2 13:36:53 2023 user.notice mwan3[8530]: Starting tracker on interface wwan (apclix0)
Wed Aug 2 13:36:54 2023 user.info mwan3rtmon[7141]: Detect rtchange event.
Wed Aug 2 13:36:54 2023 user.notice firewall: Reloading firewall due to ifup of wwan (apclix0)
This log simply shows that the repeater is started and cannot determine the cause of the exception.
