Beryl AX3000 - Adguard Encrypted DNS
Morning,
I have just purchased my first GL iNet router, a Beryl AX3000.
I would like to enable Encypted DNS, either via HTTPS or TLS, as I have a AdGuard DNS subscription with all of my rules and blocks set up, but when I look at these options on the router there is no option to manually add the encrypted server details for AdGuard, in fact Adguard doesn't appear as an option under TLS.
Is it possible to set this up and force the router to connect via Encrypted DNS, unless it is connected to a VPN?
Thank you in advance for your help
Hi there.
In the Adguard Home Settings Page, navigate to the Settings -> Encryption settings.
encryption
Check the Enable Encryption box on the top left, and input 3001 at the HTTPS port.
3001
Add the paths of your updated certificate and key, and click Save.
addcertpath
Then you can use HTTPS to visit 192.168.8.1 or 192.168.8.1:3001.
Thank you for the information, I am looking to use my private AdGuard DNS service, either over DoH or DoT
Will these instructions work for that?
These instructions look like they are to enable encrypted DNS for AdGuard Home on the router
