Beryl Cannot Access 192.168.8.1
I can connect but going to the admin panel doesn’t work. I have tried to reset by holding the button for 10 seconds. When I check my wifi settings on my computer there is no IPv4 default gateway.
Does your computer get an IP from Beryl wifi? Does ping or ssh to the Beryl work?
If yes please print the log from ssh running command:
dmesg
