I have the Beryl setup to tether internet via a USB cable from an iPhone. It works for a while, sometimes hours, sometimes days - but eventually it stops and I need to manually, physically reset the connection. The iPhone stays powered and connected to the internet, but the Beryl’s tethering disconnects.
When the tethering no longer works, I need to either unplug and replug the iPhone and have the iPhone re-“trust” the Beryl. Sometimes, I need to reset the iPhone’s network settings completely to get the “Trust this device” popup.
Is there some kind of “stay alive” or “ping” that I can enable to keep the iPhone to Beryl USB tether up and running?
Any ideas on this? I keep losing the internet connection to the iPhone (again, hard wired via USB), which makes the Beryl essentially unusable for its primary purpose.
The Beryl is running 3.125, which the device says is up to date.
Thanks @alzhao, but one of the only ways to get it to reconnect once the connection is lost is to reset the iPhone’s network settings. That reboot’s the iPhone. But the reboot has no impact on this issue.
