Beryl GL MT3000 not broadcasting Wifi anymore
I've been experiencing a strange issue with my Beryl router for the past few days: it's no longer broadcasting WiFi. I've tried connecting with different PCs and mobile phones, but none of them can see the Beryl SSID.
I've connected to it via Ethernet and it works fine. I've also tried turning off 5GHz and toggling 2.4GHz, but still no luck. I left the device off for an entire day, but the issue persists.
I'm using the original power cable and adapter, and I even tried using my phone's adapter to rule out any cable issues, but the problem remains. I'm currently on the latest firmware (4.7).
Any suggestions on how to fix this?
Thanks!
What is in the LOG ?
Try full factory reset if something was changed in the config.
what do I need to check in logs ? I flashed the beta firmware and it seem to have fixed the issue but I would like to know why this happened
