Have tried the stable release, the OPENWRT, the betas, nothing has worked. EIther the repeater fails to connect to WPA2 networks (4.7.4) or, will connect but no internet.
Here's my log on 4.7.4
== 0
Wed Jul 23 12:31:07 2025 kern.err kernel: [ 386.184284] 7981@C08L1,UpdateBeaconHandler() 2057: wdev(2) CSA counting, ignore!! (caller:AutoChSelScanNextChannel+0x3b4/0xd40 [mt_wifi])!!
Wed Jul 23 12:31:08 2025 kern.notice kernel: [ 387.217601] 7981@C14L3,ExtEventCswNotifyHandler() 2367: wdev:rax0, wdev->csa_count:0
Wed Jul 23 12:31:08 2025 kern.notice kernel: [ 387.225354] 7981@C23L3,ChannelSwitchingCountDownProc() 501: CSAEventTimer normal end!!
Wed Jul 23 12:31:08 2025 kern.notice kernel: [ 387.233377] 7981@C23L3,Dot11HCntDownTimeoutAction() 608: [RDM] Change to RD_SILENCE_MODE
Wed Jul 23 12:31:08 2025 kern.notice kernel: [ 387.242359] 7981@C23L3,Dot11HCntDownTimeoutAction() 622: wdev name(rax0), quick 1 ,ch 40
Wed Jul 23 12:31:08 2025 kern.notice kernel: [ 387.250447] 7981@C23L3,Dot11HCntDownTimeoutAction() 625: cacreq 0
Wed Jul 23 12:31:08 2025 kern.notice kernel: [ 387.256539] 7981@C13L3,Dot11HCntDownTimeoutAction() 644: CSA done and Disable Beacon: rax0
Wed Jul 23 12:31:08 2025 kern.notice kernel: [ 387.265030] 7981@C23L3,ap_phy_rrm_init_byRf() 1900: (caller:Dot11HCntDownTimeoutAction+0x284/0xa90 [mt_wifi]), wdev_idx:2.
Wed Jul 23 12:31:08 2025 kern.warn kernel: [ 387.265069] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (66:56:69:e8:0c:30), Reason 0x10
Wed Jul 23 12:31:08 2025 kern.err kernel: [ 387.284944] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Wed Jul 23 12:31:08 2025 kern.notice kernel: [ 387.286150] 7981@C13L3,ap_phy_rrm_init_byRf() 2017: Wlan_operate_init and switch channel for : rax0
Wed Jul 23 12:31:08 2025 kern.notice kernel: [ 387.300861] 7981@C23L3,RadarStateCheck() 322: RD_NORMAL_MODE
Wed Jul 23 12:31:09 2025 kern.notice kernel: [ 387.503654] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Wed Jul 23 12:31:09 2025 kern.notice kernel: [ 387.512005] 7981@C08L3,UpdateBeaconHandler() 2092: Band1 BcnInitedRnd = 3479
Wed Jul 23 12:31:09 2025 kern.notice kernel: [ 387.519157] 7981@C13L3,Dot11HCntDownTimeoutAction() 715: channel switch diff: 254 msec
Wed Jul 23 12:31:09 2025 kern.notice kernel: [ 387.527100] 7981@C23L3,DfsBuildChannelList() 4115: Done
Wed Jul 23 12:31:09 2025 kern.notice kernel: [ 387.532325] 7981@C23L3,zero_wait_dfs_switch_ch() 1215: outband ch 0, ch_stat 0
Wed Jul 23 12:31:09 2025 kern.notice kernel: [ 387.539544] 7981@C23L3,zero_wait_dfs_switch_ch() 1222: bDedicatedZeroWaitDefault == 0
Wed Jul 23 12:31:09 2025 kern.notice kernel: [ 387.547769] 7981@C23L3,Dot11HCntDownTimeoutAction() 810: cac not req 0
Wed Jul 23 12:31:09 2025 kern.debug kernel: [ 387.554561] wait channel setting success.
Wed Jul 23 12:31:09 2025 daemon.info gl-repeater[3217]: (repeater-mtk.lua:572) rax0 restore channel to auto
Wed Jul 23 12:31:09 2025 daemon.info gl-repeater[3217]: (repeater.lua:1438) switch in 30 seconds...
Wed Jul 23 12:31:09 2025 daemon.info gl-repeater[3217]: (repeater.lua:515) check status exited
Wed Jul 23 12:31:09 2025 daemon.info gl-repeater[3217]: (repeater-mtk.lua:370) listen event exited
Wed Jul 23 12:31:11 2025 kern.debug kernel: [ 389.633302] BcnCheck start after 2900 ms (ra0)
Wed Jul 23 12:31:11 2025 kern.err kernel: [ 389.993326] 7981@C13L1,MlmeEnqueueWithWdev() 5715: wdev(5) state: if down!
Wed Jul 23 12:31:13 2025 kern.debug kernel: [ 392.237299] BcnCheck start after 400 ms (ra0)
Wed Jul 23 12:31:39 2025 daemon.info gl-repeater[3217]: (repeater.lua:302) scanning...
Wed Jul 23 12:31:39 2025 kern.info kernel: [ 417.562721] Set ScanSSID =
Wed Jul 23 12:31:39 2025 kern.debug kernel: [ 417.565590] Number of channels to scan = 5
Wed Jul 23 12:31:39 2025 kern.debug kernel: [ 417.569801] bScanning = 1
Wed Jul 23 12:31:39 2025 kern.warn kernel: [ 417.830796] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (06:ae:da:24:df:5e), Reason 0x10
Wed Jul 23 12:31:39 2025 kern.err kernel: [ 417.839664] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Wed Jul 23 12:31:40 2025 kern.notice kernel: [ 418.721222] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Wed Jul 23 12:31:40 2025 kern.notice kernel: [ 418.729496] 7981@C08L3,UpdateBeaconHandler() 2092: Band0 BcnInitedRnd = 3779
Wed Jul 23 12:31:40 2025 kern.warn kernel: [ 418.984265] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (06:ae:da:24:df:5e), Reason 0x10
Wed Jul 23 12:31:40 2025 kern.err kernel: [ 418.993137] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Wed Jul 23 12:31:41 2025 kern.notice kernel: [ 419.873561] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Wed Jul 23 12:31:41 2025 kern.notice kernel: [ 419.881840] 7981@C08L3,UpdateBeaconHandler() 2092: Band0 BcnInitedRnd = 3790
Wed Jul 23 12:31:41 2025 kern.warn kernel: [ 420.128249] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (06:ae:da:24:df:5e), Reason 0x10
Wed Jul 23 12:31:41 2025 kern.err kernel: [ 420.137127] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Wed Jul 23 12:31:41 2025 kern.notice kernel: [ 420.409021] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Wed Jul 23 12:31:41 2025 kern.notice kernel: [ 420.417298] 7981@C08L3,UpdateBeaconHandler() 2092: Band0 BcnInitedRnd = 3795
Wed Jul 23 12:31:41 2025 kern.notice kernel: [ 420.424445] 7981@C23L3,cntl_scan_conf() 625: reset scan fsm, current status is 0x0
Wed Jul 23 12:31:41 2025 kern.notice kernel: [ 420.432027] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Wed Jul 23 12:31:41 2025 kern.notice kernel: [ 420.440285] 7981@C08L3,UpdateBeaconHandler() 2092: Band0 BcnInitedRnd = 3795
Wed Jul 23 12:31:41 2025 kern.debug kernel: [ 420.447416] SCAN DONE, Reset FSM/CNTL IDLE.
Wed Jul 23 12:31:41 2025 daemon.info gl-repeater[3217]: (repeater.lua:268) apcli0: found 21 networks
Wed Jul 23 12:31:41 2025 kern.info kernel: [ 420.454952] Set ScanSSID =
Wed Jul 23 12:31:41 2025 kern.debug kernel: [ 420.457818] Number of channels to scan = 5
Wed Jul 23 12:31:41 2025 kern.debug kernel: [ 420.461972] bScanning = 1
Wed Jul 23 12:31:42 2025 kern.warn kernel: [ 420.776345] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (66:56:69:e8:0c:30), Reason 0x10
Wed Jul 23 12:31:42 2025 kern.err kernel: [ 420.785215] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Wed Jul 23 12:31:42 2025 kern.debug kernel: [ 420.865296] BcnCheck start after 4500 ms (ra0)
Wed Jul 23 12:31:42 2025 kern.warn kernel: [ 420.870672] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (66:56:69:e8:0c:30), Reason 0x10
Wed Jul 23 12:31:42 2025 kern.err kernel: [ 420.879552] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Wed Jul 23 12:31:43 2025 kern.notice kernel: [ 421.753886] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Wed Jul 23 12:31:43 2025 kern.notice kernel: [ 421.762270] 7981@C08L3,UpdateBeaconHandler() 2092: Band1 BcnInitedRnd = 3808
Wed Jul 23 12:31:43 2025 kern.warn kernel: [ 422.014269] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (66:56:69:e8:0c:30), Reason 0x10
Wed Jul 23 12:31:43 2025 kern.err kernel: [ 422.023140] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Wed Jul 23 12:31:44 2025 kern.notice kernel: [ 422.993018] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Wed Jul 23 12:31:44 2025 kern.notice kernel: [ 423.001432] 7981@C08L3,UpdateBeaconHandler() 2092: Band1 BcnInitedRnd = 3820
Wed Jul 23 12:31:44 2025 kern.warn kernel: [ 423.275357] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (66:56:69:e8:0c:30), Reason 0x10
Wed Jul 23 12:31:44 2025 kern.err kernel: [ 423.284227] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Wed Jul 23 12:31:44 2025 kern.debug kernel: [ 423.469295] BcnCheck start after 2000 ms (ra0)
Wed Jul 23 12:31:45 2025 kern.notice kernel: [ 424.253612] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Wed Jul 23 12:31:45 2025 kern.notice kernel: [ 424.261968] 7981@C08L3,UpdateBeaconHandler() 2092: Band1 BcnInitedRnd = 3832
Wed Jul 23 12:31:46 2025 kern.warn kernel: [ 424.527953] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (66:56:69:e8:0c:30), Reason 0x10
Wed Jul 23 12:31:46 2025 kern.err kernel: [ 424.536822] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Wed Jul 23 12:31:46 2025 kern.notice kernel: [ 425.488901] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Wed Jul 23 12:31:46 2025 kern.notice kernel: [ 425.497257] 7981@C08L3,UpdateBeaconHandler() 2092: Band1 BcnInitedRnd = 3844
Wed Jul 23 12:31:47 2025 kern.warn kernel: [ 425.775873] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (66:56:69:e8:0c:30), Reason 0x10
Wed Jul 23 12:31:47 2025 kern.err kernel: [ 425.784746] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Wed Jul 23 12:31:47 2025 kern.warn kernel: [ 426.074559] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (66:56:69:e8:0c:30), Reason 0x10
Wed Jul 23 12:31:47 2025 kern.err kernel: [ 426.083434] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Wed Jul 23 12:31:48 2025 kern.notice kernel: [ 426.757261] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Wed Jul 23 12:31:48 2025 kern.notice kernel: [ 426.765619] 7981@C08L3,UpdateBeaconHandler() 2092: Band1 BcnInitedRnd = 3856
Wed Jul 23 12:31:48 2025 kern.notice kernel: [ 426.772767] 7981@C23L3,cntl_scan_conf() 625: reset scan fsm, current status is 0x0
Wed Jul 23 12:31:48 2025 kern.notice kernel: [ 426.781710] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Wed Jul 23 12:31:48 2025 kern.notice kernel: [ 426.790061] 7981@C08L3,UpdateBeaconHandler() 2092: Band1 BcnInitedRnd = 3856
Wed Jul 23 12:31:48 2025 kern.debug kernel: [ 426.797194] SCAN DONE, Reset FSM/CNTL IDLE.
Wed Jul 23 12:31:48 2025 daemon.info gl-repeater[3217]: (repeater.lua:268) apclix0: found 22 networks
Wed Jul 23 12:31:48 2025 daemon.info gl-repeater[3217]: (repeater.lua:1022) switch to any...
Wed Jul 23 12:31:48 2025 daemon.info gl-repeater[3217]: (repeater.lua:923) connecting to bss: ATTVqnmsKI_5GHz e8:48:b8:20:eb:1e 36 sae
Wed Jul 23 12:31:48 2025 kern.debug kernel: [ 426.816671] SetApCliEnableByWdev: I/F(apcli0) (enable = 0)
Wed Jul 23 12:31:48 2025 kern.debug kernel: [ 426.828922] Set_AutoChannelSel_Proc Alg=3
Wed Jul 23 12:31:48 2025 kern.debug kernel: [ 426.832966] Set_AutoChannelSel_Proc: Alg = 3
Wed Jul 23 12:31:48 2025 kern.warn kernel: [ 426.849702] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (06:ae:da:24:df:5e), Reason 0x10
Wed Jul 23 12:31:48 2025 kern.err kernel: [ 426.858573] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Wed Jul 23 12:31:49 2025 kern.warn kernel: [ 428.153698] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (06:ae:da:24:df:5e), Reason 0x10
Wed Jul 23 12:31:49 2025 kern.err kernel: [ 428.162573] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Wed Jul 23 12:31:49 2025 kern.debug kernel: [ 428.235646] entrytb_aid_aquire(): found non-occupied aid:4, allocated from:4
Wed Jul 23 12:31:49 2025 kern.warn kernel: [ 428.242705] 7981@C13L2,MacTableInsertEntry() 1577: New Sta:7a:24:1f:a9:d8:16
Wed Jul 23 12:31:49 2025 kern.notice kernel: [ 428.251807] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1714: Recv Assoc from STA - 7a:24:1f:a9:d8:16
Wed Jul 23 12:31:49 2025 kern.notice kernel: [ 428.261097] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2241: ASSOC Send ASSOC response (Status=0)...
Wed Jul 23 12:31:49 2025 kern.notice kernel: [ 428.270198] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 2
Wed Jul 23 12:31:49 2025 kern.notice kernel: [ 428.276228] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=2
Wed Jul 23 12:31:49 2025 kern.notice kernel: [ 428.405991] 7981@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Wed Jul 23 12:31:49 2025 kern.notice kernel: [ 428.412613] 7981@C15L3,PeerPairMsg2Action() 6303: ===>Receive msg 2
Wed Jul 23 12:31:49 2025 kern.notice kernel: [ 428.419339] 7981@C15L3,WPABuildPairMsg3() 5595: <=== send Msg3 of 4-way
Wed Jul 23 12:31:49 2025 kern.notice kernel: [ 428.425963] 7981@C15L3,PeerPairMsg4Action() 6734: ===>Receive msg 4
Wed Jul 23 12:31:49 2025 kern.warn kernel: [ 428.437484] 7981@C15L2,PeerPairMsg4Action() 7098: AP SETKEYS DONE(rax0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=1 from 7a:24:1f:a9:d8:16
Wed Jul 23 12:31:50 2025 kern.debug kernel: [ 428.673300] BcnCheck start after 3100 ms (ra0)
Wed Jul 23 12:31:50 2025 kern.notice kernel: [ 429.189764] 7981@C23L3,SelectClearChannelBusyTime() 1893: ====================================================================
Wed Jul 23 12:31:50 2025 kern.notice kernel: [ 429.201424] 7981@C23L3,SelectClearChannelBusyTime() 1899: Channel 1 : Busy Time = 18980, Skip Channel = FALSE, BwCap = TRUE
Wed Jul 23 12:31:50 2025 kern.warn kernel: [ 429.201927] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (06:ae:da:24:df:5e), Reason 0x10
Wed Jul 23 12:31:50 2025 kern.notice kernel: [ 429.212828] 7981@C23L3,SelectClearChannelBusyTime() 1899: Channel 2 : Busy Time = 14740, Skip Channel = FALSE, BwCap = TRUE
Wed Jul 23 12:31:50 2025 kern.err kernel: [ 429.221668] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Wed Jul 23 12:31:50 2025 kern.notice kernel: [ 429.233039] 7981@C23L3,SelectClearChannelBusyTime() 1899: Channel 3 : Busy Time = 5554, Skip Channel = FALSE, BwCap = TRUE
Wed Jul 23 12:31:50 2025 kern.notice kernel: [ 429.251277] 7981@C23L3,SelectClearChannelBusyTime() 1899: Channel 4 : Busy Time = 10257, Skip Channel = FALSE, BwCap = TRUE
Wed Jul 23 12:31:50 2025 kern.notice kernel: [ 429.262659] 7981@C23L3,SelectClearChannelBusyTime() 1899: Channel 5 : Busy Time = 9163, Skip Channel = FALSE, BwCap = TRUE
Wed Jul 23 12:31:50 2025 kern.notice kernel: [ 429.274040] 7981@C23L3,SelectClearChannelBusyTime() 1899: Channel 6 : Busy Time = 57573, Skip Channel = FALSE, BwCap = TRUE
Wed Jul 23 12:31:50 2025 kern.notice kernel: [ 429.285421] 7981@C23L3,SelectClearChannelBusyTime() 1899: Channel 7 : Busy Time = 23774, Skip Channel = FALSE, BwCap = TRUE
Wed Jul 23 12:31:50 2025 kern.notice kernel: [ 429.296803] 7981@C23L3,SelectClearChannelBusyTime() 1899: Channel 8 : Busy Time = 16884, Skip Channel = FALSE, BwCap = TRUE
Wed Jul 23 12:31:50 2025 kern.notice kernel: [ 429.308183] 7981@C23L3,SelectClearChannelBusyTime() 1899: Channel 9 : Busy Time = 20958, Skip Channel = FALSE, BwCap = TRUE
Wed Jul 23 12:31:50 2025 kern.notice kernel: [ 429.319565] 7981@C23L3,SelectClearChannelBusyTime() 1899: Channel 10 : Busy Time = 22687, Skip Channel = FALSE, BwCap = TRUE
Wed Jul 23 12:31:50 2025 kern.notice kernel: [ 429.330945] 7981@C23L3,SelectClearChannelBusyTime() 1899: Channel 11 : Busy Time = 13587, Skip Channel = FALSE, BwCap = TRUE
Wed Jul 23 12:31:50 2025 kern.notice kernel: [ 429.342325] 7981@C23L3,SelectClearChannelBusyTime() 1902: ====================================================================
Wed Jul 23 12:31:50 2025 kern.notice kernel: [ 429.353709] 7981@C23L3,SelectClearChannelBusyTime() 2138: Rule 3 Channel Busy time value : Select Primary Channel 3
Wed Jul 23 12:31:50 2025 kern.notice kernel: [ 429.364147] 7981@C23L3,SelectClearChannelBusyTime() 2140: Rule 3 Channel Busy time value : Min Channel Busy = 5554
Wed Jul 23 12:31:50 2025 kern.notice kernel: [ 429.374488] 7981@C23L3,SelectClearChannelBusyTime() 2145: Rule 3 Channel Busy time value : BW = 20
Wed Jul 23 12:31:50 2025 kern.notice kernel: [ 429.383442] 7981@C23L3,SelectClearChannelBusyTime() 2179: [SelectClearChannelBusyTime] - band0 END
Wed Jul 23 12:31:50 2025 kern.notice kernel: [ 429.392393] 7981@C23L3,AutoChSelScanNextChannel() 3092: Current channel = 4 , selected new channel = 3
Wed Jul 23 12:31:51 2025 kern.notice kernel: [ 429.520472] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Wed Jul 23 12:31:51 2025 kern.notice kernel: [ 429.528741] 7981@C08L3,UpdateBeaconHandler() 2092: Band0 BcnInitedRnd = 3882
Wed Jul 23 12:31:51 2025 kern.notice kernel: [ 429.536113] 7981@C23L3,rtmp_set_channel() 2892: (caller:AutoChSelScanNextChannel+0x260/0xd40 [mt_wifi]), Channel(3), quick_ch_change:1.
Wed Jul 23 12:31:51 2025 kern.notice kernel: [ 429.548507] 7981@C23L3,perform_channel_change() 2529: (caller:rtmp_set_channel+0x260/0x500 [mt_wifi]), Channel(3), quick_ch_change:1.
Wed Jul 23 12:31:51 2025 kern.notice kernel: [ 429.560717] 7981@C23L3,ap_phy_rrm_init_byRf() 1900: (caller:perform_channel_change+0x23c/0xa70 [mt_wifi]), wdev_idx:0.
Wed Jul 23 12:31:51 2025 kern.notice kernel: [ 429.571605] 7981@C08L3,MacTableResetNonMapWdev() 2097: (caller:ap_phy_rrm_init_byRf+0x3e8/0x6b8 [mt_wifi]), wdev_idx:0.
Wed Jul 23 12:31:51 2025 kern.notice kernel: [ 429.592454] 7981@C13L3,ap_phy_rrm_init_byRf() 2017: Wlan_operate_init and switch channel for : ra0
Wed Jul 23 12:31:51 2025 kern.notice kernel: [ 429.719660] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Wed Jul 23 12:31:51 2025 kern.notice kernel: [ 429.727923] 7981@C08L3,UpdateBeaconHandler() 2092: Band0 BcnInitedRnd = 3884
Wed Jul 23 12:31:51 2025 kern.notice kernel: [ 429.735068] 7981@C13L3,ap_phy_rrm_init_byRf() 2017: Wlan_operate_init and switch channel for : apcli0
Wed Jul 23 12:31:51 2025 kern.warn kernel: [ 429.744443] 7981@C00L2,ap_phy_rrm_init_byRf() 2053: Scan(ACS) is running, can not do OverLapping scan here!
Wed Jul 23 12:31:51 2025 kern.notice kernel: [ 429.754187] 7981@C23L3,perform_channel_change() 2848: (Channel=3)
Wed Jul 23 12:31:51 2025 kern.err kernel: [ 429.760280] 7981@C23L1,DfsBuildChannelList() 4070: [RDM]: wdev is not 5G.
Wed Jul 23 12:31:51 2025 kern.notice kernel: [ 429.767064] 7981@C23L3,zero_wait_dfs_switch_ch() 1215: outband ch 0, ch_stat 0
Wed Jul 23 12:31:51 2025 kern.notice kernel: [ 429.774293] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Wed Jul 23 12:31:51 2025 kern.debug kernel: [ 429.774295] wait channel setting success.
Wed Jul 23 12:31:51 2025 kern.notice kernel: [ 429.786553] 7981@C08L3,UpdateBeaconHandler() 2092: Band0 BcnInitedRnd = 3884
Wed Jul 23 12:31:54 2025 daemon.info dnsmasq-dhcp[5355]: DHCPREQUEST(br-lan) 192.168.8.110 7a:24:1f:a9:d8:16
Wed Jul 23 12:31:54 2025 daemon.info dnsmasq-dhcp[5355]: DHCPACK(br-lan) 192.168.8.110 7a:24:1f:a9:d8:16 MacBookPro
Wed Jul 23 12:31:54 2025 daemon.info gl-repeater[3217]: (repeater-mtk.lua:572) ra0 restore channel to auto
Wed Jul 23 12:31:54 2025 daemon.info gl-repeater[3217]: (repeater-mtk.lua:535) update macaddr of apclix0 to EE:BC:7F:ED:3C:41
Wed Jul 23 12:31:54 2025 kern.warn kernel: [ 433.429130] 7981@C01L2,RTMP_COM_IoctlHandle() 1517: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_INIT
Wed Jul 23 12:31:54 2025 kern.warn kernel: [ 433.437306] 7981@C01L2,RTMP_COM_IoctlHandle() 1494: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_UP
Wed Jul 23 12:31:54 2025 kern.notice kernel: [ 433.445411] WiFi@C01L3,wifi_sys_open() 856: wdev idx = 5
Wed Jul 23 12:31:54 2025 kern.notice kernel: [ 433.451086] 7981@C18L3,BuildChannelList() 507:
Wed Jul 23 12:31:54 2025 kern.debug kernel: [ 433.458808] wdev_attr_update(): wdevId5 = 9e:83:c4:5b:37:f7
Wed Jul 23 12:31:54 2025 kern.info kernel: [ 433.464442] apclix0: update addr to: ee:bc:7f:ed:3c:41
Wed Jul 23 12:31:54 2025 kern.notice kernel: [ 433.469674] 7981@C08L3,hw_ctrl_flow_v2_open() 13: wdev_idx=5
Wed Jul 23 12:31:54 2025 kern.info kernel: [ 433.478261] extif_set_dev(apclix0)
Wed Jul 23 12:31:54 2025 kern.info kernel: [ 433.481705] mtk_ppe_dev_register_hook : ineterface apclix0 register (4)
Wed Jul 23 12:31:54 2025 kern.debug kernel: [ 433.489221] SetApCliEnableByWdev: I/F(apcli1) (enable = 0)
Wed Jul 23 12:31:54 2025 kern.err kernel: [ 433.495487] 7981@C12L1,Set_ApCliPMFMFPC_Proc() 2003: [PMF]: MFPC=1, MFPR=0, SHA256=0
Wed Jul 23 12:31:54 2025 kern.debug kernel: [ 433.507663] SetApCliEnableByWdev: I/F(apcli1) (enable = 1)
Wed Jul 23 12:31:55 2025 kern.notice kernel: [ 433.516890] 7981@C23L3,Set_Channel_Proc() 1665: Channel(36), Cert(0), Quick(1)
Wed Jul 23 12:31:55 2025 kern.notice kernel: [ 433.524421] 7981@C23L3,rtmp_set_channel() 2892: (caller:Set_Channel_Proc+0x128/0x618 [mt_wifi]), Channel(36), quick_ch_change:1.
Wed Jul 23 12:31:55 2025 kern.notice kernel: [ 433.536267] 7981@C23L3,perform_channel_change() 2529: (caller:rtmp_set_channel+0x260/0x500 [mt_wifi]), Channel(36), quick_ch_change:1.
Wed Jul 23 12:31:55 2025 kern.notice kernel: [ 433.548413] WiFi@C00L3,NotifyChSwAnnToPeerAPs() 1490: Send CSA NewChannel:36
Wed Jul 23 12:31:55 2025 kern.notice kernel: [ 433.555580] 7981@C23L3,HcUpdateCsaCntByChannel() 599: Channel(40).
Wed Jul 23 12:31:55 2025 kern.notice kernel: [ 433.561863] 7981@C00L3,HcUpdateCsaCntByChannel() 651: CSAEventTimer start(wdev_counter=1)
Wed Jul 23 12:31:55 2025 kern.notice kernel: [ 433.566091] 7981@C23L3,MakeChSwitchAnnounceIEandExtend() 667: Channel=36, bw=2
Wed Jul 23 12:31:55 2025 kern.notice kernel: [ 433.570052] 7981@C23L3,perform_channel_change() 2848: (Channel=36)
Wed Jul 23 12:31:55 2025 kern.notice kernel: [ 433.583533] 7981@C23L3,DfsBuildChannelList() 4115: Done
Wed Jul 23 12:31:55 2025 kern.notice kernel: [ 433.588846] 7981@C23L3,zero_wait_dfs_switch_ch() 1215: outband ch 0, ch_stat 0
Wed Jul 23 12:31:55 2025 kern.notice kernel: [ 433.596108] 7981@C23L3,zero_wait_dfs_switch_ch() 1222: bDedicatedZeroWaitDefault == 0
Wed Jul 23 12:31:55 2025 kern.debug kernel: [ 433.977297] BcnCheck start after 900 ms (ra0)
Wed Jul 23 12:31:56 2025 kern.notice kernel: [ 434.617254] 7981@C14L3,ExtEventCswNotifyHandler() 2367: wdev:rax0, wdev->csa_count:0
Wed Jul 23 12:31:56 2025 kern.notice kernel: [ 434.625005] 7981@C23L3,ChannelSwitchingCountDownProc() 501: CSAEventTimer normal end!!
Wed Jul 23 12:31:56 2025 kern.notice kernel: [ 434.633014] 7981@C23L3,Dot11HCntDownTimeoutAction() 608: [RDM] Change to RD_SILENCE_MODE
Wed Jul 23 12:31:56 2025 kern.notice kernel: [ 434.641971] 7981@C23L3,Dot11HCntDownTimeoutAction() 622: wdev name(rax0), quick 1 ,ch 36
Wed Jul 23 12:31:56 2025 kern.notice kernel: [ 434.650058] 7981@C23L3,Dot11HCntDownTimeoutAction() 625: cacreq 0
Wed Jul 23 12:31:56 2025 kern.notice kernel: [ 434.656152] 7981@C13L3,Dot11HCntDownTimeoutAction() 644: CSA done and Disable Beacon: rax0
Wed Jul 23 12:31:56 2025 kern.notice kernel: [ 434.664642] 7981@C23L3,ap_phy_rrm_init_byRf() 1900: (caller:Dot11HCntDownTimeoutAction+0x284/0xa90 [mt_wifi]), wdev_idx:2.
Wed Jul 23 12:31:56 2025 kern.warn kernel: [ 434.664693] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (66:56:69:e8:0c:30), Reason 0x10
Wed Jul 23 12:31:56 2025 kern.err kernel: [ 434.684530] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Wed Jul 23 12:31:56 2025 kern.notice kernel: [ 434.685735] 7981@C13L3,ap_phy_rrm_init_byRf() 2017: Wlan_operate_init and switch channel for : rax0
Wed Jul 23 12:31:56 2025 kern.notice kernel: [ 434.700445] 7981@C23L3,RadarStateCheck() 322: RD_NORMAL_MODE
Wed Jul 23 12:31:56 2025 kern.notice kernel: [ 434.902579] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Wed Jul 23 12:31:56 2025 kern.notice kernel: [ 434.910943] 7981@C08L3,UpdateBeaconHandler() 2092: Band1 BcnInitedRnd = 3933
Wed Jul 23 12:31:56 2025 kern.notice kernel: [ 434.918179] 7981@C13L3,ap_phy_rrm_init_byRf() 2017: Wlan_operate_init and switch channel for : apclix0
Wed Jul 23 12:31:56 2025 kern.notice kernel: [ 434.928892] 7981@C23L3,ap_phy_rrm_init_byRf() 2031: Updated RaBf info bw by wdev ~~~
Wed Jul 23 12:31:56 2025 kern.notice kernel: [ 434.936706] 7981@C13L3,Dot11HCntDownTimeoutAction() 715: channel switch diff: 272 msec
Wed Jul 23 12:31:56 2025 kern.notice kernel: [ 434.944644] 7981@C23L3,DfsBuildChannelList() 4115: Done
Wed Jul 23 12:31:56 2025 kern.notice kernel: [ 434.949872] 7981@C23L3,zero_wait_dfs_switch_ch() 1215: outband ch 0, ch_stat 0
Wed Jul 23 12:31:56 2025 kern.notice kernel: [ 434.957099] 7981@C23L3,zero_wait_dfs_switch_ch() 1222: bDedicatedZeroWaitDefault == 0
Wed Jul 23 12:31:56 2025 kern.notice kernel: [ 434.965171] 7981@C23L3,Dot11HCntDownTimeoutAction() 810: cac not req 0
Wed Jul 23 12:31:56 2025 kern.notice kernel: [ 434.971740] 7981@C23L3,Set_Channel_Proc() 1697: wait channel setting success.
Wed Jul 23 12:31:56 2025 kern.notice kernel: [ 434.978937] 7981@C03L3,MtCmdTxPwrShowInfo() 13944: ucTxPowerInfoCatg: 2, BandIdx: 1
Wed Jul 23 12:31:56 2025 kern.notice kernel: [ 434.986740] 7981@C03L3,MtCmdTxPwrShowInfo() 13973: (ret = 0)
Wed Jul 23 12:31:56 2025 kern.debug kernel: [ 434.992409] [mtf_txpower_all_rate_info] band_idx:1 pwr:42 ChBand:5G ePAGain:0
Wed Jul 23 12:31:56 2025 daemon.notice netifd: Interface 'wwan' is enabled
Wed Jul 23 12:31:57 2025 kern.debug kernel: [ 436.004850] Set_ByPassCac_Proc(): set CAC value to 1
Wed Jul 23 12:31:58 2025 kern.debug kernel: [ 436.581301] BcnCheck start after 3300 ms (ra0)
Wed Jul 23 12:31:58 2025 kern.warn kernel: [ 436.586162] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x184/0x358 [mt_wifi]
Wed Jul 23 12:31:58 2025 kern.debug kernel: [ 436.596927] entrytb_aid_aquire(): found non-occupied aid:5, allocated from:4
Wed Jul 23 12:31:59 2025 kern.debug kernel: [ 438.003466] Mac: ee:bc:7f:ed:3c:41 was aleady existed.
Wed Jul 23 12:32:00 2025 kern.warn kernel: [ 438.673700] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x184/0x358 [mt_wifi]
Wed Jul 23 12:32:00 2025 kern.err kernel: [ 438.683020] 7981@C09L1,cntl_connect_request() 412: Return since CNTL not IDLE,CNTL(2),SYNC(0),AUTH(3),ASSOC(0)
Wed Jul 23 12:32:00 2025 kern.debug kernel: [ 439.005425] Set_ByPassCac_Proc(): set CAC value to 1
Wed Jul 23 12:32:00 2025 kern.debug kernel: [ 439.209300] BcnCheck start after 800 ms (ra0)
Wed Jul 23 12:32:02 2025 kern.warn kernel: [ 440.773778] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x184/0x358 [mt_wifi]
Wed Jul 23 12:32:02 2025 kern.err kernel: [ 440.783092] 7981@C09L1,cntl_connect_request() 412: Return since CNTL not IDLE,CNTL(2),SYNC(0),AUTH(3),ASSOC(0)
Wed Jul 23 12:32:04 2025 kern.warn kernel: [ 442.869703] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x184/0x358 [mt_wifi]
Wed Jul 23 12:32:04 2025 kern.err kernel: [ 442.879019] 7981@C09L1,cntl_connect_request() 412: Return since CNTL not IDLE,CNTL(2),SYNC(0),AUTH(3),ASSOC(0)
Wed Jul 23 12:32:06 2025 kern.warn kernel: [ 444.965711] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x184/0x358 [mt_wifi]
Wed Jul 23 12:32:06 2025 kern.err kernel: [ 444.975024] 7981@C09L1,cntl_connect_request() 412: Return since CNTL not IDLE,CNTL(2),SYNC(0),AUTH(3),ASSOC(0)
Wed Jul 23 12:32:08 2025 kern.warn kernel: [ 447.065710] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x184/0x358 [mt_wifi]
Wed Jul 23 12:32:08 2025 kern.err kernel: [ 447.075030] 7981@C09L1,cntl_connect_request() 412: Return since CNTL not IDLE,CNTL(2),SYNC(0),AUTH(3),ASSOC(0)
Wed Jul 23 12:32:10 2025 kern.warn kernel: [ 449.161705] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x184/0x358 [mt_wifi]
Wed Jul 23 12:32:10 2025 kern.err kernel: [ 449.171020] 7981@C09L1,cntl_connect_request() 412: Return since CNTL not IDLE,CNTL(2),SYNC(0),AUTH(3),ASSOC(0)
