witty
October 23, 2021, 8:53pm
My Beryl running on https://fw.gl-inet.com/firmware/mt1300/testing/openwrt-mt1300-3.203-1012.bin stops working within several minutes and no WiFi is available any longer
Setup:
WiFi Repeater
WiFi incl. Wireguard VPN (connecting to my home) - only 5G
Guest WiFi - only 5G
After some minutes the 2 WiFis disappear - and re-appearing some minutes later again
Using original Power Supply - but also tried others → same result
Should I get a hardware replacement?
mbg
October 25, 2021, 10:54am
2
Why are you using testing firmware?
witty
October 25, 2021, 6:31pm
3
Sorry forgot to mention, that I for sure first used latest standard firmware, but was pointed to the testing firmware while reading another thread.
Same behavior on my side.
alzhao
October 26, 2021, 8:06am
4
Are you using as repeater in public places?
If the wifi disappear for some time and appear again, It seems that the repeater breaks then reconnected.
witty
October 26, 2021, 12:03pm
5
No, it seems Beryl is rebooting from time to time …
This happens even if I am at home and testing with my very stable WiFi as source for Beryl‘s repeater.
alzhao
October 27, 2021, 1:36pm
6
If it reboot, the log is gone. We have a firmware that record logs when kernel crash. Sorry to point you to that thread.
Hello Good People,
As there are many users report MT1300 has stability issues, or crashes and reboot itself, we compiled a firmware that can store log when the router crashes.
The firmware is here GL.iNet download center
Download the openwrt-mt1300-3.203-0826-oops-track.bin and flash to your router.
When the route crash and reboot, you can use the following command to get the log.
dd if=/dev/mtd7 of=/last.log
You can get the log using winscp, scp etc and post in this thread.
Until now, we…
