I’m notice that the Beryl Services from GL.iNet Use VPN is not functional on snapshot firmware 4.2.0 dated 1/15. Even after or before toggle on the button as am noticed that the DDNS is same of the ip address .
Highly appreciate if you could rectify the issue accordingly.
Thanks!
It takes time for DNS records to be synchronized between DNS servers.
You can verify more quickly by command specifying the original DNS record server.
nslookup xxxxxxx.glddns.com ddns.glddns.com
Btw, I have tested other models and working except beryl.
This is a bug related to nftable adaption. Thanks for reporting.
