I’ve just had it with this thing.
Sometimes when I connect a 2.4ghz device all wifi shuts off, even tho in the software in the router says it’s enabled. Or the wifi just goes offline completely for no reason, yet still shows it’s connected. Or the 2.4ghz cannot allow someone to connect.
Right now i’m using the router only with Ethernet because the wifi refuses to function. It will show up when I reboot the router, then go offline completely. In the router it says the firmware is working fine.
I have tried reverting the firmware, using the beta firmware, using the nightly snapshot firmware, hard resetting, at this point nothing changes the situation.
Anyone have any ideas?
Thanks
