[Beta Release] Beryl AX (GL-MT3000) v4.8.2 with New WireGuard Obfuscation Support
Thanks.
The guide is still not working:
Try it here directly
I think I might have found the issue — it looks like you’re currently using the initial beta version.
We fixed a few issues and released an updated beta firmware afterward.:face_with_spiral_eyes:
It might be worth downloading and trying the latest beta from our official website.
I downloaded it on Thursday from your official website. I didn't find any newer version.
If you downloaded it on Thursday, then it should already be the latest version.
Followed your instruction to the letter but cannot get it to work on my Flint 2 server trying to connect from my mobile phone as the client using the AmneziaWG app. Unsure where I am going wrong here. Regular WG working well with no issues at all.
Main-Issue was spaces between the Line in the H-Parameters
wrong: from the conf of the flint is creating
H1 = 142858110 - 142858329
right:
H1 = 142858110-142858329
you need to manually edit away this spaces from the conf that the Flint is giving you, before uploading the conf in the AmenziaWG-App
Thanks @Tagor. You are a star and a fountain of knowledge. That’s worked a treat.
This issue does exist, and the root cause is exactly as @Tagor pointed out.:saluting_face:
The issue has already been fixed, but I’m not sure yet whether a new beta firmware will be released to replace the current one.
I’ll push for a new beta firmware to be released.
Mt3000 model has
4.8.3 snapshot version but has no obfuscation?
How do snapshot version gets updated when click check new version
I see my router has jan 2026 4.8.3 snapshot
Is this excludes amnesia obfuscation
If tried to check new versions, many already available but check check upgrade not showing new snapshot versions
Do your team auto upgrade snapshot versions on some users devices as don't remember if i did a snapshot version upgrade
Thx
Firmware from the Snapshot branch never pushed to user devices via OTA, users generally download it from the Firmware Center and upload and install it manually in the GL GUI.
Please download the v4.8.2 Beta firmware from the Firmware Center and install it manually
Does Snapshot version 4.8.3 includes amnesia wireguard obfuscation?
I don't see it , will wait for ga release thx
Beta firmware versions are no longer available for download. I installed the very latest snapshot, followed by the latest OpenWRT 24, but the Amnezia WG protocol still didn’t work. Neither the first version nor the second. What should I do? Which version is currently required to use this protocol?
Where can I download the firmware for the second version?
They released 4.9.0 beta 1 for the Flint 2 today. The Beryl AX release should follow soon.
We have released v4.9.0 beta for MT3000, which supports AmneziaWG including 2.0, so you can use this beta firmware.
Just installed on my Beryl AX. Now waiting patiently for the Beryl 7 update :wink: .
The team's hard work is appreciated.
Thank you for the new firmware. Unfortunately, however, the AmneziaWG VPN connection is extremely unstable. I have a GL-MT3000 router.
1. If I install the Amnezia app and use it to create a configuration file, it does not work on the router. The router reports an error. After manually correcting the file, the router accepts it.
2. The VPN scripts themselves are unstable. The router regularly simply stops transmitting any data. I suspect the problem is with the DNS.
It seems AdguardHome is not working since the previous 4.8 Beta
I did not use Adguard. And my DNS in auto status.
