Bidirectional site to site not working
I have set up a site to site vpn using two GL.iNet GL-AX1800. V4.68 and one has V4.7 firmware. On one i setup both the OpenVPN and Wireguard servers. I exported the config files to the second router and connected successfully with the client on either server. From the client LAN i can connect to devices on the server LAN successfully but cannot connect to devices on the client LAN from the server LAN. Remote Access LAN is enabled on both the client and server sides. What am i missing
Did the same using a GL.iNet GL-MT3000 v4.8 as a client and got the same results.
Please try to add a route rule in the VPN server that points to the client's LAN address.
