Thanks @jeffsf for suggesting where to look. There are a lot of entities in my config, so the ‘logs’ below are somewhat long. I am not using the WAN ports as I only have a single ethernet running into my main switch, therefore they are fine to not be up.
cat /etc/config/wireless
config wifi-device 'wifi0'
option type 'qcawifi'
option macaddr 'my:ma:ca:dd:rs:84'
option hwmode '11g'
option country 'GB'
option channel 'auto'
option txpower '20'
config wifi-iface
option device 'wifi0'
option network 'lan'
option mode 'ap'
option blockdfschan '1'
option ifname 'ath0'
option encryption 'psk2+tkip+ccmp'
option key 'mypsk1'
option ssid 'ssid1'
config wifi-device 'wifi1'
option macaddr 'my:ma:ca:dd:rs:85'
option htmode 'VHT20'
option txpower '23'
option country 'GB'
option hwmode '11ac'
config wifi-iface
option device 'wifi1'
option mode 'ap'
option ifname 'ath1'
option key 'mypsk1'
option ssid 'ssid1'
config wifi-iface 'wif120r0'
option network 'ifvlan120'
option mode 'ap'
option ssid 'ssid120'
option encryption 'psk2+ccmp'
option key 'psk120'
config wifi-iface 'wif120r1'
option mode 'ap'
option key 'ssid120'
config wifi-iface 'wif80r1'
option network 'ifvlan80'
option mode 'ap'
option ssid 'ssid80'
option key 'psk80'
config wifi-iface 'wif150r1'
option network 'ifvlan150'
option mode 'ap'
option ssid 'ssid150'
option key 'psk150'
config wifi-iface 'wif80r0'
option mode 'ap'
option key 'psk80'
config wifi-iface 'wif150r0'
option mode 'ap'
option key 'psk150'
cat /etc/config/network
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'auto'
config interface 'lan'
option ifname 'eth1'
option type 'bridge'
option _orig_ifname 'eth1 ath0 ath1'
option _orig_bridge 'true'
option proto 'dhcp'
option hostname 'glinet-WLAN-AP3'
option ieee1905managed '1'
config interface 'wan'
option ifname 'eth0'
option proto 'dhcp'
option hostname 'GL-B1300-123-5G'
config interface 'wan6'
option proto 'dhcpv6'
config switch
option name 'switch0'
option reset '1'
option enable_vlan '1'
config switch_vlan
option device 'switch0'
option vlan '1'
option ports '0t 1 2 3 4'
config switch_vlan
option vlan '2'
option ports '0t 5'
config switch_ext
option name 'QosPtMode'
option port_id '1'
option mode 'dscp'
option status 'enable'
config switch_ext
option port_id '2'
option mode 'dscp'
config switch_ext
option port_id '3'
option mode 'dscp'
config switch_ext
option port_id '4'
option mode 'dscp'
config switch_ext
option port_id '5'
option mode 'dscp'
config switch_vlan 'swvlan120'
option vlan '120'
option vid '120'
option ports '0t 3t 4t 5t'
config switch_vlan 'swvlan80'
option vlan '80'
option vid '80'
config switch_vlan 'swvlan150'
option vlan '150'
option vid '150'
config switch_vlan 'swvlan90'
option vlan '90'
option vid '90'
config interface 'ifvlan120'
option proto 'dhcp'
option ifname 'eth1.120'
config interface 'ifvlan80'
option proto 'dhcp'
option ifname 'eth1.80'
config interface 'ifvlan150'
option proto 'dhcp'
option ifname 'eth1.150'
config interface 'ifvlan90'
option proto 'dhcp'
option ifname 'eth1.90'
ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: miireg: <> mtu 0 qdisc noop state DOWN mode DEFAULT group default
link/generic
3: ifb0: <BROADCAST,NOARP> mtu 1500 qdisc hyfi_pfifo_fast state DOWN mode DEFAULT group default qlen 32
link/ether nw:ma:ca:dd:rs:db brd ff:ff:ff:ff:ff:ff
4: ifb1: <BROADCAST,NOARP> mtu 1500 qdisc hyfi_pfifo_fast state DOWN mode DEFAULT group default qlen 32
link/ether ab:ma:ca:dd:rs:04 brd ff:ff:ff:ff:ff:ff
5: gre0@NONE: <NOARP> mtu 1476 qdisc noop state DOWN mode DEFAULT group default
link/gre 0.0.0.0 brd 0.0.0.0
6: gretap0@NONE: <BROADCAST,MULTICAST> mtu 1462 qdisc hyfi_pfifo_fast state DOWN mode DEFAULT group default qlen 1000
link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
7: bond0: <BROADCAST,MULTICAST,MASTER> mtu 1500 qdisc noop state DOWN mode DEFAULT group default
link/ether cd:ma:ca:dd:rs:92 brd ff:ff:ff:ff:ff:ff
8: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc hyfi_pfifo_fast state DOWN mode DEFAULT group default qlen 1000
link/ether my:ma:ca:dd:rs:84 brd ff:ff:ff:ff:ff:ff
9: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc hyfi_pfifo_fast master br-lan state UP mode DEFAULT group default qlen 1000
link/ether my:ma:ca:dd:rs:85 brd ff:ff:ff:ff:ff:ff
10: wifi0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN mode DEFAULT group default qlen 2699
link/ieee802.11 my:ma:ca:dd:rs:84 brd ff:ff:ff:ff:ff:ff
11: wifi1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN mode DEFAULT group default qlen 2699
link/ieee802.11 my:ma:ca:dd:rs:85 brd ff:ff:ff:ff:ff:ff
12: br-ifvlan120: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default
13: eth1.120@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-ifvlan120 state UP mode DEFAULT group default
16: br-ifvlan80: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default
17: eth1.80@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-ifvlan80 state UP mode DEFAULT group default
18: br-ifvlan90: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default
19: eth1.90@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-ifvlan90 state UP mode DEFAULT group default
20: br-lan: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default
29: ath0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-lan state UNKNOWN mode DEFAULT group default
30: ath01: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-ifvlan120 state UNKNOWN mode DEFAULT group default
link/ether ot:ma:ca:dd:rs:84 brd ff:ff:ff:ff:ff:ff
31: ath02: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-ifvlan80 state UNKNOWN mode DEFAULT group default
link/ether yr:ma:ca:dd:rs:84 brd ff:ff:ff:ff:ff:ff
32: ath03: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-ifvlan150 state UNKNOWN mode DEFAULT group default
link/ether hd:ma:ca:dd:rs:84 brd ff:ff:ff:ff:ff:ff
33: ath1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-lan state UNKNOWN mode DEFAULT group default
34: ath11: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-ifvlan120 state UNKNOWN mode DEFAULT group default
link/ether ot:ma:ca:dd:rs:85 brd ff:ff:ff:ff:ff:ff
35: ath12: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-ifvlan80 state UNKNOWN mode DEFAULT group default
link/ether yr:ma:ca:dd:rs:85 brd ff:ff:ff:ff:ff:ff
36: ath13: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-ifvlan150 state UNKNOWN mode DEFAULT group default
link/ether hd:ma:ca:dd:rs:85 brd ff:ff:ff:ff:ff:ff
37: br-ifvlan150: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default
38: eth1.150@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-ifvlan150 state UP mode DEFAULT group default
ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: miireg: <> mtu 0 qdisc noop state DOWN group default
link/generic
3: ifb0: <BROADCAST,NOARP> mtu 1500 qdisc hyfi_pfifo_fast state DOWN group default qlen 32
4: ifb1: <BROADCAST,NOARP> mtu 1500 qdisc hyfi_pfifo_fast state DOWN group default qlen 32
5: gre0@NONE: <NOARP> mtu 1476 qdisc noop state DOWN group default
6: gretap0@NONE: <BROADCAST,MULTICAST> mtu 1462 qdisc hyfi_pfifo_fast state DOWN group default qlen 1000
7: bond0: <BROADCAST,MULTICAST,MASTER> mtu 1500 qdisc noop state DOWN group default
8: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc hyfi_pfifo_fast state DOWN group default qlen 1000
inet6 fe80::e695:5678:9012:c184/64 scope link
9: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc hyfi_pfifo_fast master br-lan state UP group default qlen 1000
inet6 fe80::e695:5678:9012:c185/64 scope link
10: wifi0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN group default qlen 2699
11: wifi1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN group default qlen 2699
12: br-ifvlan120: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default
inet 192.168.120.3/24 brd 192.168.120.255 scope global br-ifvlan120
13: eth1.120@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-ifvlan120 state UP group default
16: br-ifvlan80: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default
inet 192.168.80.3/24 brd 192.168.80.255 scope global br-ifvlan80
17: eth1.80@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-ifvlan80 state UP group default
18: br-ifvlan90: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default
inet 192.168.90.2/24 brd 192.168.90.255 scope global br-ifvlan90
19: eth1.90@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-ifvlan90 state UP group default
20: br-lan: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default
inet 192.168.8.247/24 brd 192.168.8.255 scope global br-lan
29: ath0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-lan state UNKNOWN group default
30: ath01: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-ifvlan120 state UNKNOWN group default
inet6 fe80::1234:5678:9012:c184/64 scope link
31: ath02: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-ifvlan80 state UNKNOWN group default
inet6 fe80::ec95:5678:9012:c184/64 scope link
32: ath03: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-ifvlan150 state UNKNOWN group default
inet6 fe80::f095:5678:9012:c184/64 scope link
33: ath1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-lan state UNKNOWN group default
34: ath11: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-ifvlan120 state UNKNOWN group default
inet6 fe80::1234:5678:9012:c185/64 scope link
35: ath12: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-ifvlan80 state UNKNOWN group default
inet6 fe80::ec95:5678:9012:c185/64 scope link
36: ath13: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-ifvlan150 state UNKNOWN group default
inet6 fe80::f095:5678:9012:c185/64 scope link
37: br-ifvlan150: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default
38: eth1.150@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-ifvlan150 state UP group default
brctl show
bridge name bridge id STP enabled interfaces
br-ifvlan120 7fff.e4956e44c185 no ath01
ath11
eth1.120
br-ifvlan150 7fff.e4956e44c185 no ath03
ath13
eth1.150
br-ifvlan80 7fff.e4956e44c185 no ath02
ath12
eth1.80
br-ifvlan90 7fff.e4956e44c185 no eth1.90
br-lan 7fff.e4956e44c185 no ath0
ath1
eth1
