On Brume you can install AdGuard.
Pi-Hole or AdGuard on Brume? Pls try and judge by yoursefl.
First you need to change to Ubuntu System on your Brume.
Then you can install AdGuard. This is a much better way than using Raspberry Pi because of Brume’s gigabit Ethernet switch. You can put your other Wi-Fi router in AP mode and use Brume for gateway.
Check out the guide here
https://github.com/gl-inet/mv1000-ubuntu-image/blob/master/adguard/MV1000%20Install%20AdGuardHome%20Guide.md
