Hello, I am connecting wireguard vpn on client GL-A1300 which connects over the internet to a wireguard server running openwrt also. When I connect my GL-A1300 via LAN to any computer, with wireguard vpn enabled, I can still look up the local router login via IP address the GL-A1300 connects to as a repeater. I would like to block this. I don’t have Allow Remote Access LAN enabled. Is there another setting or command in ssh? I want to completely block any local access including DNS leaks or IP leaks, anything else I should be doing. Tests on ipleak.net and dnsleaktest.com have passed and show no leaks.
