Ordered a couple of mt300n v2 units from amazon over the weekend and sitting here trying to get into one.
It never shows up on the wifi network, pressing reset or not, nothing.
It never picks up a dhcp IP no matter which port I use. Doc says LAN is set to DHCP.
Only the first LED comes on, nothing else.
They are brand new, had to break the seal to open the box.
Finally figured out that the V2 needs more power so after doing that, it turned on wifi and picked up a dhcp IP.
Now I can reach the setup screen BUT, it won’t respond when setting the time zone.
Clicking on Next does nothing.
I would if I could get the company to do it but they aren’t doing it right now. The only way I could get this to work on a V2 is if it could run the V1 firmware which it cannot.
