Broadcast / Scan Not woking
I have a 300m Mini smart router connected to a small industrial network.
I want to commission Devices/PLCs on the network.
There for I Scan that network with TIA Portal / Proneta
To locate PLCs TIA Portal uses layer 2 communications: DCP and LLDP
But now device are shown, is het router blocking this kind of protocols ?
My laptop is connected on Wifi.
The devices/PLCs are connected to the LAN interface
The Wan port is not used.
Is there a setting that allows these protocols to function on the LAN ?
Thx.
A router is an L3 network device, so L2 protocols will get dropped mostly.
Not sure if you could enable them because you would set your router into bridge-mode then - and I am not sure if this is possible.
Are you using the mini router as repeater?
Pls set it up using extender.
